Is this how to define a function with optional parameters that are passed by reference, so that the function can return mutiple values. I found several threads on the forum - but none dealt with optional parameters passed by reference. If I followed the examples, I would get an error about something like int& and int were incompatible… “void myfunc(int& parm1=0);” would not compile.
error: default argument for ‘int& stack’ has type ‘int’
I got it to work by defining a “dummy” global variable “optArg”, and writing the function prototype like this: “void myfunc(int& parm1=optArg);”.
My question is, is that the correct way to do it? Do you have any recommendations as to how? I know it works (see my code below), but it ‘bothers’ me having to define that dummy variable. Any suggestions?
SD card acode file read
Version to test using optional arguments
#include <SPI.h>
#include <SD.h>
int optArg=0; // dummy optional argument
File file_ACode;
// Script object
int ScriptAction[127];
int ScriptDescription[127];
int ScriptOption[127];
int ScriptStack[127];
int ScriptSize;
int MainScript;
#define EndMain ScriptSize
boolean readln_ACode(int &action, int &desc=optArg, int &option=optArg, int &stack=optArg)
String inputstring="";
int inputvalues[4];
byte inputchar;
byte index=0;
boolean Done=false;
inputchar='\0';
while ((! Done) && (file_ACode.available())) {
inputchar=file_ACode.read();
if (inputchar==',') {
// comma found, have chars for number
inputvalues[index]=inputstring.toInt();
index ++;
inputstring="";
if (inputchar == 13 ) {
// EOL found; last number found
Done = true;
inputstring="";
if (inputchar >= '0' && inputchar <='9') {
// character is a digit; append to string
inputstring=String(inputstring+String(char(inputchar)));
action =inputvalues[0]; // all Global variables
desc =inputvalues[1];
option =inputvalues[2];
stack =inputvalues[3];
return file_ACode.available();
boolean more=true;
int index=0;
int filler=0;
while (!Serial) {
; // wait for serial port to connect. Needed for Leonardo only
Serial.print(F("Initializing SD card..."));
pinMode(10, OUTPUT);
if (!SD.begin(4)) {
Serial.println(F("initialization failed!"));
return;
Serial.println(F("initialization done."));
if (SD.exists("acode2.csv")) {
Serial.println("acode2.csv exists.");
else {
Serial.println(F("acode2.csv doesn't exist."));
// open file
Serial.println(F("Opening acode2.csv..."));
file_ACode = SD.open("acode2.csv");
more=readln_ACode(ScriptSize,MainScript);
Serial.print(F("Script Size....... = "));
Serial.println(ScriptSize);
Serial.print(F("Main Script starts @ "));
Serial.println(MainScript);
if (more) {
Serial.println("More lines available");
while (more) {
index++;
more=readln_ACode(ScriptAction[index],ScriptDescription[index],ScriptOption[index],ScriptStack[index]);
Serial.print(index);
Serial.print(" ");
Serial.println("");
Serial.println("Done loading...");
Serial.println("Starting dump");
for(int index=1;index<=ScriptSize;index++) {
Serial.println(ScriptAction[index]);
Serial.println(ScriptDescription[index]);
Serial.println(ScriptOption[index]);
Serial.println(ScriptStack[index]);
Serial.println(F("___"));
while(true){}
