Options for camera gimball control using Arduino
Exactly it does have 3axis stabilisation, this would be perfect especially if it is possible
to turn it off in flight but pitch and roll first. If I can get that to work it would be great.
So to recap:
I need a gyro/accelerometer (this can be used from the multiwii controller board)
I need a ULN2004 or Quad Hbridge depending on the type of steppermotor used.
I can connect these together but do need to programm it to get it to actually work together.
Is this correct?
The gimball will be perfectly balanced so the force needed from the motor's won't be to high,
it does need to be able to accelerate fast and smooth (as seen in the second video)
The multiwii controller has loads of inputs and exits, woud it be possible to reconfigure the
outputs to match these output pins that you talked about?
My Apologies for the large amount of questions. I'm kind of a newbie, getting it working smooth
with servo's was a big step for me, reprogramming this to accomodate steppermotor for me
quite a big project.
If I am correct I should be able to reconfigure the outputs of the MW board using the arduino tool
and connect it to the steppermotor controller and steppermotor. Do I need to program this steppermotor
controller? or is it just a sort of translator?
