Options for streaming data from arduino to pc via ethernet?
I want to stream data from an Arduino to a PC via Ethernet. I could use MQTT but would depend on a broker. Which options do I have besides of MQTT?
Is there anything stopping you from installing a broker on the PC?
If you are operating in a restricted environment then your sending options are dictated by the listening software you are allowed to run on the PC.
EthernetClient object wraps a TCP socket. A normal TCP socket is connected to IP address and port.
A TCP server listens on a port. If server is contacted by a remote client socket, it creates a local socket connected with the remote client socket and returns a socket object wrapping the socket. Everything you write or print to a EthernetClient is send to that one remote socket.
client socket
   if (client.connect(serverIP, PORT)) {
     client.print("request\n");
     String response = client.readStringUntil('\n');
     Serial.println(response);
     client.stop();
@mikb55 Unfortunatelly a broker based technology is no option for me in this project.
I'd like to use WebSockets but could not find a library other than GPL, LGPL, etc. which are no options for me.
