Opto isolate Temperature and humidity module SDA Serial data
Is it possible to isolate with optocoupler this sensor: Temperature and humidity module AM2305 ?
Using separated power 5VDC for the sensor
isolate SDA pin for reading, writing sensor data
I think I need bi-directional optocoupler
If possible please help me a simple circuit draw to understand it :cold_sweat:
Thank You
A two-way open collector optocoupler... I have to think about that... okay, I did think about it. There are optocouplers for I2C, that is the same (this is 1 signal wire, I2C has 2).
This page is about a that: http://www.embedded.com/design/prototyping-and-development/4025023/Opto-electrical-isolation-of-the-I2C-Bus
There are chips for that, I never heard about them, but I found these : ADuM1250, Si840x, HCPL-060L, and so on.
Thank You I'm working on it.
DId you find a solution in the end?
piashaw:
Since Mayerf stopped posting I assume it worked. A quick thanks would have been nice though eh?
Sorry for late replay!
Yes I solved it find a circuit as Peter_n mentioned http://www.embedded.com/design/prototyping-and-development/4025023/Opto-electrical-isolation-of-the-I2C-Bus.
Figure 4: High-speed opto-couplers achieve 100kHz operation
Working perfect
