optocoupler software issue need help
so I am trying to get the arduino to read a 12-13.8v signal through an optocoupler, I know the optocoupler works as i can get it to turn on/off an LED withouth the arduino. however When I try to get the arduino to read a high/low from the optocoupler output cuircut and power pin 4 when high and not when low, the led just remains iluminated. here is my code and following that is how i have wired the optocoupler;
int optoInput = 7;
int grnLed = 4;
pinMode(optoInput, INPUT);
pinMode(grnLed, OUTPUT);
if (digitalRead(optoInput) == HIGH)
digitalWrite(grnLed, HIGH);
digitalWrite(grnLed, LOW);
What am I doing wrong?
Connect the other output lead of the opto to pin 7, the lead that was on pin 7 to ground, lose the
resistor and do
  pinMode (7, INPUT_PULLUP) ;
Then the opto is acting just like a push-button switch.
Your current configuration is always pulling pin 7 HIGH through the leakage current of the opto's outputs.
added pic
Thanks pancake works fine now.
