Optoisolator TLP521
Hi all, I have a simple question: I would like to use an optoisolator to control some devices from digital output of arduino board. In my case optoisolator is a TLP521, can I connect directly digital output to anode and cathode to gnd or I have to use a resistor between digital output of arduino and anode of TLP521?
many thanks Fabrizio
Ciao Fabrizio
You should use a 270 ohm resistor from one of the arduino pin and connect it to the anode of the optocoupler the cathode is connected to ground.
massimo
Grazie :)
