Hi floresta, Thanks for your reply.
I have fixed the problem. It seems that the older Hitachi HD44700A00 chips were slower than newer versions.
I modified LiquidCrystal.cpp by increasing the delays between commands.
I hope that this helps others who may run into a rare, similar '‘slow’ LCD.
The date code on mine is 9885RI, so it was made in August 1998.
#include "LiquidCrystal.h"
#include <stdio.h>
#include <string.h>
#include <inttypes.h>
#include "Arduino.h"
// When the display powers up, it is configured as follows:
// 1. Display clear
// 2. Function set:
//Â Â DL = 1; 8-bit interface data
//Â Â N = 0; 1-line display
//Â Â F = 0; 5x8 dot character font
// 3. Display on/off control:
//Â Â D = 0; Display off
//Â Â C = 0; Cursor off
//Â Â B = 0; Blinking off
// 4. Entry mode set:
//Â Â I/D = 1; Increment by 1
//Â Â S = 0; No shift
// Note, however, that resetting the Arduino doesn't reset the LCD, so we
// can't assume that its in that state when a sketch starts (and the
// LiquidCrystal constructor is called).
LiquidCrystal::LiquidCrystal(uint8_t rs, uint8_t rw, uint8_t enable,
  uint8_t d0, uint8_t d1, uint8_t d2, uint8_t d3,
  uint8_t d4, uint8_t d5, uint8_t d6, uint8_t d7)
 init(0, rs, rw, enable, d0, d1, d2, d3, d4, d5, d6, d7);
LiquidCrystal::LiquidCrystal(uint8_t rs, uint8_t enable,
 init(0, rs, 255, enable, d0, d1, d2, d3, d4, d5, d6, d7);
  uint8_t d0, uint8_t d1, uint8_t d2, uint8_t d3)
 init(1, rs, rw, enable, d0, d1, d2, d3, 0, 0, 0, 0);
 init(1, rs, 255, enable, d0, d1, d2, d3, 0, 0, 0, 0);
void LiquidCrystal::init(uint8_t fourbitmode, uint8_t rs, uint8_t rw, uint8_t enable,
 _rs_pin = rs;
 _rw_pin = rw;
 _enable_pin = enable;
Â
 _data_pins[0] = d0;
 _data_pins[1] = d1;
 _data_pins[2] = d2;
 _data_pins[3] = d3;
 _data_pins[4] = d4;
 _data_pins[5] = d5;
 _data_pins[6] = d6;
 _data_pins[7] = d7;
 pinMode(_rs_pin, OUTPUT);
 // we can save 1 pin by not using RW. Indicate by passing 255 instead of pin#
 if (_rw_pin != 255) {
  pinMode(_rw_pin, OUTPUT);
 pinMode(_enable_pin, OUTPUT);
Â
 if (fourbitmode)
  _displayfunction = LCD_4BITMODE | LCD_1LINE | LCD_5x8DOTS;
  _displayfunction = LCD_8BITMODE | LCD_1LINE | LCD_5x8DOTS;
Â
 begin(16, 1);Â
void LiquidCrystal::begin(uint8_t cols, uint8_t lines, uint8_t dotsize) {
 if (lines > 1) {
  _displayfunction |= LCD_2LINE;
 _numlines = lines;
 _currline = 0;
 // for some 1 line displays you can select a 10 pixel high font
 if ((dotsize != 0) && (lines == 1)) {
  _displayfunction |= LCD_5x10DOTS;
 // SEE PAGE 45/46 FOR INITIALIZATION SPECIFICATION!
 // according to datasheet, we need at least 40ms after power rises above 2.7V
 // before sending commands. Arduino can turn on way befer 4.5V so we'll wait 50
 delayMicroseconds(50000);
 // Now we pull both RS and R/W low to begin commands
 digitalWrite(_rs_pin, LOW);
 digitalWrite(_enable_pin, LOW);
  digitalWrite(_rw_pin, LOW);
Â
 //put the LCD into 4 bit or 8 bit mode
 if (! (_displayfunction & LCD_8BITMODE)) {
  // this is according to the hitachi HD44780 datasheet
  // figure 24, pg 46
  // we start in 8bit mode, try to set 4 bit mode
  write4bits(0x03);
  delayMicroseconds(5500); // wait min 4.1ms
  // second try
  write4bits(0x03);
 Â
  // third go!
  write4bits(0x03);
  delayMicroseconds(200);
  // finally, set to 4-bit interface
  write4bits(0x02);
  // page 45 figure 23
  // Send function set command sequence
  command(LCD_FUNCTIONSET | _displayfunction);
  delayMicroseconds(5500); // wait more than 4.1ms
  // second try
  // third go
 // finally, set # lines, font size, etc.
 command(LCD_FUNCTIONSET | _displayfunction);Â
 // turn the display on with no cursor or blinking default
 _displaycontrol = LCD_DISPLAYON | LCD_CURSOROFF | LCD_BLINKOFF;Â
 display();
 // clear it off
 clear();
 // Initialize to default text direction (for romance languages)
 _displaymode = LCD_ENTRYLEFT | LCD_ENTRYSHIFTDECREMENT;
 // set the entry mode
 command(LCD_ENTRYMODESET | _displaymode);
/********** high level commands, for the user! */
void LiquidCrystal::clear()
 command(LCD_CLEARDISPLAY); // clear display, set cursor position to zero
 delayMicroseconds(5000); // this command takes a long time!
void LiquidCrystal::home()
 command(LCD_RETURNHOME); // set cursor position to zero
void LiquidCrystal::setCursor(uint8_t col, uint8_t row)
 int row_offsets[] = { 0x00, 0x40, 0x14, 0x54 };
 if ( row >= _numlines ) {
  row = _numlines-1;  // we count rows starting w/0
Â
 command(LCD_SETDDRAMADDR | (col + row_offsets[row]));
// Turn the display on/off (quickly)
void LiquidCrystal::noDisplay() {
 _displaycontrol &= ~LCD_DISPLAYON;
 command(LCD_DISPLAYCONTROL | _displaycontrol);
void LiquidCrystal::display() {
 _displaycontrol |= LCD_DISPLAYON;
// Turns the underline cursor on/off
void LiquidCrystal::noCursor() {
 _displaycontrol &= ~LCD_CURSORON;
void LiquidCrystal::cursor() {
 _displaycontrol |= LCD_CURSORON;
// Turn on and off the blinking cursor
void LiquidCrystal::noBlink() {
 _displaycontrol &= ~LCD_BLINKON;
void LiquidCrystal::blink() {
 _displaycontrol |= LCD_BLINKON;
// These commands scroll the display without changing the RAM
void LiquidCrystal::scrollDisplayLeft(void) {
 command(LCD_CURSORSHIFT | LCD_DISPLAYMOVE | LCD_MOVELEFT);
void LiquidCrystal::scrollDisplayRight(void) {
 command(LCD_CURSORSHIFT | LCD_DISPLAYMOVE | LCD_MOVERIGHT);
// This is for text that flows Left to Right
void LiquidCrystal::leftToRight(void) {
 _displaymode |= LCD_ENTRYLEFT;
// This is for text that flows Right to Left
void LiquidCrystal::rightToLeft(void) {
 _displaymode &= ~LCD_ENTRYLEFT;
// This will 'right justify' text from the cursor
void LiquidCrystal::autoscroll(void) {
 _displaymode |= LCD_ENTRYSHIFTINCREMENT;
// This will 'left justify' text from the cursor
void LiquidCrystal::noAutoscroll(void) {
 _displaymode &= ~LCD_ENTRYSHIFTINCREMENT;
// Allows us to fill the first 8 CGRAM locations
// with custom characters
void LiquidCrystal::createChar(uint8_t location, uint8_t charmap[]) {
 location &= 0x7; // we only have 8 locations 0-7
 command(LCD_SETCGRAMADDR | (location << 3));
 for (int i=0; i<8; i++) {
  write(charmap[i]);
/*********** mid level commands, for sending data/cmds */
inline void LiquidCrystal::command(uint8_t value) {
 send(value, LOW);
inline size_t LiquidCrystal::write(uint8_t value) {
 send(value, HIGH);
 return 1; // assume sucess
/************ low level data pushing commands **********/
// write either command or data, with automatic 4/8-bit selection
void LiquidCrystal::send(uint8_t value, uint8_t mode) {
 digitalWrite(_rs_pin, mode);
 // if there is a RW pin indicated, set it low to Write
Â
 if (_displayfunction & LCD_8BITMODE) {
  write8bits(value);
  write4bits(value>>4);
  write4bits(value);
void LiquidCrystal::pulseEnable(void) {
 delayMicroseconds(1); Â
 digitalWrite(_enable_pin, HIGH);
 delayMicroseconds(1);  // enable pulse must be >450ns
 delayMicroseconds(100); // commands need > 37us to settle
void LiquidCrystal::write4bits(uint8_t value) {
 for (int i = 0; i < 4; i++) {
  pinMode(_data_pins[i], OUTPUT);
  digitalWrite(_data_pins[i], (value >> i) & 0x01);
 pulseEnable();
void LiquidCrystal::write8bits(uint8_t value) {
 for (int i = 0; i < 8; i++) {
Â
 pulseEnable();
