"OR and "AND" question
I'm working on a router reseter ..
basically sends out 4 pings to two differnet IP addresses.
if either one returns I want a positive result.
If both fail I want a Negative result.
getting confussed with my "OR" and "AND".
Not sure how to tidy up my else.. as I need ELSE and two false pingRet , pingRet2.
cheers
david
delay(2000);
  bool pingRet; // pingRet stores the ping() success (true/false)
  bool pingRet2; // pingRet stores the ping() success (true/false)
#ifdef ledOut
  startPing();
#endif
  ICMPPing ping(pingSocket);
  pingRet = ping(4, pingAddr, buffer);
  pingRet2 = ping(4, pingAddr2, buffer);
  Serial.println(buffer);
#ifdef ledOut
  delay(250);
  endPing();
  delay(2000);
#endif
#ifdef ledOut
  if(pingRet) // Failure  I want to have an OR here so any Successful ping shows Network OK.
  if(pingRet2) // Failure
    pingSuccess();
    lcd.clear();
    lcd.setCursor(0,0);
    lcd.print("    ping ok");
    lcd.setCursor(0,1);
      lcd.print(buffer);
      delay(20);
// I need pingRet and pingRet2 to both be false here to generate this network fail.
    pingFail();
    lcd.clear();
    lcd.setCursor(0,0);
    lcd.print("  Network FAIL ");
    delay(2000);
    lcd.setCursor(0,0);
    lcd.print("  Sarian Reset  ");
    delay(10000);
#endif
  delay(delayMS);
If you used { and } with every if statement, you'd know the answer.
  if(pingRet)
  { // Failure  //////////// I want this to be OR by here
      pingSuccess();
Both pingRet and pingRet2 must be true for pingSuccess to be called.
Of course, you can combine them into one statement, using either && (and) or || (or), whichever meets your needs:
  if(pingRet && pingRet2)
     // Both must be true to get here
  if(pingRet || pingRet2)
     // Either one of the statements being true will get to here
Both being true is no more positive than just one, one is enough...
I'd take the fail by default view and go something like this:
// set both pingRet and pingRet2 as false out here to start
// then do the stuff which pings and sets pingRet and pingRet2 to actual values
     // Either one of the statements being true will get to here so do success stuff
    // Neither was true to get here so do failure stuff
JimboZA:
Both being true is no more positive than just one, one is enough…
I’d take the fail by default view and go something like this:
thats exactly what i’ve done… many thanks… all working
