Hello,
I am trying to make a reaction time tester and have it be two players for a class project, but when button 2 is released before button 1, it displays that player 1 won with the difference in time being around 3 milliseconds. I think this is because it runs the first while statement before it goes to the second, but how would I fix it?
#include <LiquidCrystal.h>
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
int LEDR = 6; // Red Led pin 6
int LEDB = 7; // Blue Led pin 7
int LEDGr = 8; // Green Led pin 8
int Button1=10;
int Button2=9;
int COLOR;
int PSE; // variable pause
int TME; // Time
int RTME1=0; // Reaction Time
int RTME2=0;
lcd.begin(16, 2);
pinMode(LEDR, OUTPUT);
pinMode(LEDB, OUTPUT);
pinMode(LEDGr, OUTPUT);
pinMode(Button1, INPUT);
pinMode(Button2, INPUT);
digitalWrite(LEDR, HIGH); // All lights are switched "on".
digitalWrite(LEDB, HIGH);
digitalWrite(LEDGr, HIGH);
lcd.clear(); // Clear screen.
lcd.print("Hold Button to");
lcd.setCursor(0,1); // move to second line.
lcd.print("start.");
while (digitalRead(Button1)==LOW && digitalRead(Button2)==LOW) // The test does not start until the button is pushed (and held down).
{tone(13,1200,30);
delay(1400);
noTone(13);
RTME1=0;
RTME2=0;
lcd.clear();
digitalWrite(LEDR, LOW); // switch off the "start"light.
digitalWrite(LEDB, LOW);
digitalWrite(LEDGr, LOW);
randomSeed(analogRead(0)); //Random noise from pin 0
COLOR = random(1,4); // Generate a random color.
PSE=random(500,1200); // Select a random pause between the lights (to increase the surprise effect).
while (COLOR!=1 && digitalRead(Button1)==HIGH && digitalRead(Button2)==HIGH)// This loop is repeated while color is Green or Blue AND button is held down.
delay(PSE);
PSE=random(750,1200); // Select a random pause between the lights (to increase the surprise effect).
if (COLOR == 2)
{digitalWrite(LEDGr, HIGH);}
if (COLOR == 3)
{digitalWrite(LEDB, HIGH);}
delay(PSE);
COLOR = random(1,4); // Select a random color.
if (COLOR == 1 && digitalRead(Button1)==HIGH && digitalRead(Button2)==HIGH)// This loop is executed if the color is red.
delay(PSE);
TME=millis(); // Time since this program has started (so Blue or Green loop included).
while (digitalRead(Button1)==HIGH)// This loop runs until you have released the button, hence the reaction time.
{delay(1);}
lcd.display();
RTME1=millis()-TME; // Time since Led is Red, hence reaction time.
lcd.print("Doc:");
lcd.print(RTME1);
while (digitalRead(Button2)==HIGH)
{delay(1);}
lcd.display();
RTME2=millis()-TME; // Time since Led is Red, hence reaction time.
lcd.setCursor(0,1);
lcd.print("McQueen:");
lcd.print(RTME2);
if (RTME1<RTME2)
delay(3000);
lcd.clear();
lcd.print("Winner: Doc");
lcd.setCursor(0,1);
lcd.print ("Time:");
lcd.print (RTME1);
if (RTME2<RTME1)
delay(3000);
lcd.clear();
lcd.print("Winner: McQueen");
lcd.setCursor(0,1);
lcd.print("Time:");
lcd.print(RTME2);
if (COLOR != 1) // This step is executed if the color is NOT red but the Push button was released (wrong action).
lcd.print("Released too");
lcd.print("soon !!!");
tone(13,3000,1500);
noTone(13);
while (digitalRead(Button1)==LOW && digitalRead(Button2)==LOW) // The test does not re-start until the button is pushed once.
{delay(10);}
digitalWrite(LEDR, HIGH); // Resets all lights to begin again.
lcd.clear();
lcd.setCursor(0,1);
int Time=0;
