Order of execution in my Waveshield code.
Hello. I successfully merged my Arduino waveshield sketch, which plays back different files according to which number is sent to the serial port, with some sample code from the Waveshield’s sit which allows for pitch control.
I’ve got it so that I can control the pitch from a potentiometer, but it only changes the pitch at the beginning of each triggered sound - I have monitored the analogRead to see that I am getting continuous readings - but I am not able to get continuous control of the pitch.
I have a feeling I have just not put the code in the right place - i’m hoping someone with more experienced eyes can see where I might have gone wrong. I commented out bits that were interfering with the normal function of the sketch, but kept them there in case they are necessary. Code follows, thank you for looking!
#include <AF_Wave.h>
#include <avr/pgmspace.h>
#include “util.h”
#include “wave.h”
AF_Wave card;
File f;
Wavefile wave;
#define redled 9
// set up serial port
pinMode(2, OUTPUT);
pinMode(3, OUTPUT);
pinMode(4, OUTPUT);
pinMode(5, OUTPUT);
pinMode(redled, OUTPUT);
// open memory card
if (!card.init_card()) {
putstring_nl(“Card init failed!”); return;
if (!card.open_partition()) {
putstring_nl(“No partition!”); return;
if (!card.open_filesys()) {
putstring_nl(“Couldn’t open filesys”); return;
if (!card.open_rootdir()) {
putstring_nl(“Couldn’t open dir”); return;
Serial.println(analogRead(5), DEC);
char c = 0;
if(Serial.available()) {
c = Serial.read();
int16_t potval;
uint32_t newsamplerate;
int16_t lastpotval = 0;
#define HYSTERESIS 3
//Serial.println(c, BYTE);
switch (c) {
case ‘1’:
playfile(“1.WAV”);
case ‘2’:
playfile(“2.WAV”);
case ‘3’:
playfile(“3.WAV”);
case ‘4’:
playfile(“4.WAV”);
case ‘5’:
playfile(“5.WAV”);
case ‘6’:
playfile(“6.WAV”);
case ‘7’:
playfile(“7.WAV”);
case ‘8’:
playfile(“8.WAV”);
default:
Serial.println(“dogs and cats”);
void playfile(char *name) {
Serial.print(“bang”);
int16_t potval;
// stop any file already playing
if (wave.isplaying) {
wave.stop();
// close file if open
card.close_file(f);
// play specified file
f = card.open_file(name);
if (f && wave.create(f)) {
wave.play();
// while (wave.isplaying) {
potval = analogRead(5);
//if ( ((potval - lastpotval) > HYSTERESIS) || ((lastpotval - potval) > HYSTERESIS)) {
putstring("pot = "); Serial.println(potval, DEC);
putstring("tickspersam = “); Serial.print(wave.dwSamplesPerSec, DEC); putstring(” → ");
newsamplerate = wave.dwSamplesPerSec;
newsamplerate *= potval;
newsamplerate /= 512; // we want to ‘split’ between sped up and slowed down.
if (newsamplerate > 24000) {
newsamplerate = 24000;
wave.setSampleRate(newsamplerate);
Serial.println(newsamplerate, DEC);
lastpotval = potval;
//delay(100);
