Hello!
I have an ASC46AK unit (ASM46AK stepper + ASD18A-K driver). It was controlled by a Panasonic FPG-C32T2 PLC, but it is crashed. I removed the PLC, and now I would like to replace it with an arduino. Is it possible?
I have attached the manuals and catalog for the ASC46AK unit, please download it.
According to the manual the arduino would be a good choice, since it has 5VDC outputs.
I have wires only on pin 2,3,9,10,11,12,25,26 on the I/O connector of the driver, and the driver is in 2-pulse mode.
Here is what I did:
The driver has an external power supply (gnd/24vdc)
I/O connector pins:
pins 2,3 are power supply (gnd and 24VDC)
pins 10,12 go to arduino outputs.
pins 25,26 go to arduino inputs.
pins 9, 11 are not connected.
the driver and the arduino have common GND.
As the manual said, in 2-pulse mode (page 34), I have to use pin 10 (CW), and pin 12 (CCW) and send the pulse there depending on the direction. So I made a program, what send 5V pwm to pin 10.
Nothing happens. I am sure, that I do something wrong with the connection. I am kinda amateur in electronics, please help me to find out how to connect it! Thank you ![]()
ASC_connection_operation.pdf (590 KB)
HM-6163-12E.pdf (675 KB)
