origin stepper motor
hai good day.
i have a conveyor system about 2 meter long. i have some problem to origin back conveyor to home position.
byte directionPinCon = 30;
byte stepPinCon = 34;
int numberOfStepsCon = 15;
//byte ledPin = 7;
int pulseWidthMicrosCon = 1;  // microseconds
int microbetweenStepsCon = 100; // milliseconds - or try 1000 for slower steps
int sensor = 2;
pinMode(directionPinCon,OUTPUT);
pinMode(stepPinCon,OUTPUT);
pinMode(sensor,INPUT);
int sensorStatus = digitalRead(sensor);
if ( sensorStatus == HIGH ) {
  digitalWrite(directionPinCon, HIGH);
  digitalWrite(stepPinCon, HIGH);
   // delayMicroseconds(pulseWidthMicrosCon); // this line is probably unnecessary
   digitalWrite(stepPinCon, LOW);
   delay(microbetweenStepsCon);
 else {
  digitalWrite(directionPinCon,LOW);
  digitalWrite(stepPinCon,LOW);
i want to stop stepper motor if the proximity sensor detect the metal plate that i put on conveyor but the conveyor did't stop. can anybody give the solution to me. thanks
So what actually happens when you run the program?
I think you need a variable to record the state of the system - perhaps call it okToMove
When the sensor is triggered your program should set okToMove = false; and the part of your program that makes the motor move should only do so if (okToMove == true) {
You have not told us how you would tell the system it is appropriate to start moving again so I have not addressed that.
If you use the AutoFormat tool it will indent your code to make it much easier to read.
...R
