Original Wifi Shield not working
Hello everybody,
today the Arduino Wifi Shield arrived and i wanted to connect my arduino Mega 2560 with my home network. I put the shield on the arduino mega and connected the arduino mega via usb with my laptop. I tried ConnectWithWPA and ScanNetworks from skretch example but the error is "WiFi shield not present".
No led on the shield lights up. I don't now what the problem is, but maybe you can help me?
Thanks!
Is it mating correctly with the ICSP header on the Mega2560?
Yes, it is. Maybe i accidently touched the reset button. I read that the reset button on the shield does not only reset the userprograms but deletes the wifi firmware as well. Could this be the problem? I will try to reinstall this firmware and will report then.
jakimarks:
Where did you read that? Not everything you read on the Internet is true. (for example, that comment.)
The hardware page has a comment from someone suggesting jumpering pins 7 and 3.
I read it on the official arduino site:
"The reset button on the shield resets both the HDG104 and the Arduino board."
jakimarks:
Where is the "but deletes the wifi firmware as well" part?
RESET means "reset the machine." Not "deletes firmware."
Hmm.. I thought that resetting the HDG104 means deleting the firmware. But now i know thats wrong. Thanks! Aaaaand you were right: Connecting pins 7 and 3 is the solution. Do you know why? I really want to know why.
Thank you :slight_smile:
