os x 10.10 "Arduino as ISP" problem
I am using an Uno with the ISP sketch loaded to program another 328p based board.
Board programming works fine on a windows machine.
Trying to set up the environment on a OS X10.10 machine but the 'upload using programmer' gives an error when I try to upload....
--- excerpt from the IDE ---- Programmer Type : STK500 Description : Atmel STK500 Version 1.x firmware avrdude: Send: A [41] . [80] [20] avrdude: Recv: . [14] avrdude: Recv: . [10] avrdude: Recv: . [14]
avrdude: stk500_getparm(): (a) protocol error, expect=0x14, resp=0x14 avrdude: Send: A [41] . [81] [20] avrdude: Recv: . [02]
avrdude: stk500_getparm(): (a) protocol error, expect=0x14, resp=0x02 avrdude: Send: A [41] . [82] [20] avrdude: Recv: . [10]
avrdude: stk500_getparm(): (a) protocol error, expect=0x14, resp=0x10 avrdude: Send: A [41] . [98] [20] avrdude: Recv: . [14] avrdude: Recv: . [01] avrdude: Recv: . [10] Hardware Version: -1593720580 Firmware Version: -1073745912.10
Topcard : STK502
Note, this is only a problem when using "upload using programmer"
The Uno port is /dev/tty.usbmodem1421
Seems to be a problem with the ftdi drivers that come with os x 10
I implemented a "workaround"
  • installed virtualbox with usb extensions
  • installed an ubuntu image. added arduino ide
  • ran the 'upload using programmer' from inside the vm and all works fine --- Uno as ISP with custom 328p board connected
will get back to checking what the problem with osx drivers when I have more time
