system
October 17, 2014, 3:36pm
1
After installing Yosemite today a few of my apps will not launch... like Matlab...but that's another issue.
When I went to launch Arduino I was presented with the following message:
So after installing the suggested JAVA legacy install located here:
http://support.apple.com/kb/DL1572
Everything worked fine.
So for those of you wondering if Arduino works on the GA version of Yosemite....yes it does 8)
system
October 17, 2014, 3:48pm
2
Verified against ver 1.0.6 as well.
pjt
November 7, 2014, 1:26am
3
Does this fix revert to a less secure version of Java (ver 6) systemwide? Or will this only install a version for use with the Arduino IDE and co-exist with the newer version?
system
November 7, 2014, 11:56pm
4
I bought an arduino uno recently. I tried to launch arduino and got the same message. However, when I click on the link (Download Java for OS X 2017-001 ), it doesn't work. It doesn't load anything. Why is that? Any ideas why?
regards,
system
November 9, 2014, 10:47pm
5
What were your exact steps? The link to apple support loads a blank page.
Thanks!
system
November 9, 2014, 10:55pm
6
The link is working once again.
The direct link to the install package incase the page doesn't load again.
http://support.apple.com/downloads/DL1572/en_US/JavaForOSX2014-001.dmg
system
November 11, 2014, 2:10pm
7
Yes Arduino works, but have you tried to upgrade?
system
January 9, 2015, 10:25am
8
I also recently installed Yosemite and had the same problems.
I followed the links and reinstalled the older Java.
Now the Arduino IDE loads ok, but...
There are no boards listed when they should all be shown in a pulldown menu under the tools menu.
It's odd because the pulldown showing the ports works fine. Any ideas?
Thanks
system
January 9, 2015, 9:19pm
9
Ignore my last - problem solved.
I'd been using a dropbox folder as my sketch folder - so I can access my files on multiple computers.
When I set the sketch folder back to the one in the C drive documents folder, and restarted the IDE, it suddenly found all the boards again.
Somewhere one of the files it needs got moved or corrupted presumably.
Thanks anyway
