Hey all,
I'm trying to send some sensor values using OSC. an example of what I'd like to send is the following:
Blockquote
cue/1/go
My full code looks like this:
#include <SPI.h>
#include <Ethernet.h>
#include <ArdOSC.h>
#include "SR04.h" // this is the ultrasound lib
// this is the ultrasonic pin setup
#define TRIG_PIN 7
#define ECHO_PIN 6
//set up the ultrasonic bits
SR04 sr04 = SR04(ECHO_PIN,TRIG_PIN);
long a;
byte myMac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
byte myIp[] = { 192, 168, 1, 177 };
int destPort=12000;
byte destIp[] = { 192, 168, 1, 69 };
OSCClient client;
//create new osc message
OSCMessage global_mes;
void setup(){
Serial.begin(9600);//Initialization of Serial Port
Ethernet.begin(myMac ,myIp);
void loop(){
int distance_value=sr04.Distance(); // This is the distance value in int format
char* start_text = "/cue/";
char* end_text = "/go";
char formatted_message[30];
Serial.print(end_text);
strcpy (formatted_message,start_text); //
strcat (formatted_message,distance_value);
strcat (formatted_message,end_text);
Serial.print(formatted_message);
global_mes.setAddress(destIp,destPort);
global_mes.beginMessage(formatted_message);
client.send(&global_mes);
global_mes.flush(); //object data clear
My issues is trying to merge the start_text, distance_value, and end_text into one variable. I've had a look in the library, and the function will only accept a char type. The console currently looks like this:
Blockquote
13:06:58.018 -> /cue//go
13:06:58.066 -> /cue/⸮⸮⸮⸮⸮Eޭ⸮⸮⸮⸮/go
13:06:58.112 -> /cue/⸮⸮⸮/go
13:06:58.159 -> /cue/⸮⸮⸮/go
13:06:58.301 -> /cue//go
13:06:58.348 -> /cue//go
13:06:58.348 -> /cue/⸮/go
13:06:58.394 -> /cue/⸮/go
13:06:58.441 -> /cue/⸮/go
What do I need to do to the distance_value variable to make this work?
