OSC outIp - formatting the IP for a network range (multiple destinations)
I would like to send OSC messages to multiple computers on the same private network.
The network devices will have fixed IP addresses using a 192.168.0.0/24 network and I can send OSC messages to a single IP address using the following string:
IPAddress outIp(192, 168, 1, 64);
However I can't work out if I can change the outIp to a network range? Something like the following I guess but this is not working:
IPAddress outIp(192, 168, 1, 0/24);
Thanks,
Michael.
You would probably just need to iterate through all the IP addresses you want to send messages to:
IPAddress outIp(192, 168, 1, 0);
for (int octet = 0; octet <= 255; ++octet) {
  outIp[3] = octet;
  // send to outIp
That assumes you actually want to send to all 256 IP addresses.
Good idea, didn’t think of that and easy to restrict to a short range, will give it a test. Thanks.
pert:
  outIp[3] = octet;
  // send to outIp
@pert - I would send the OSC message to a fixed number of computers to share sensor and random data, most likely 2-3 but I guess could be more but not the whole network :slight_smile:
You could also put the specific IP addresses in an array, then use a for loop to iterate through the elements of the array:
const IPAddress outIp[] = {IPAddress(192, 168, 1, 0), IPAddress(192, 168, 1, 1), IPAddress(192, 168, 1, 2)};
for (byte ipCounter = 0; ipCounter < sizeof(outIp) / sizeof(outIp[0]); ++ipCounter) {
  // send to outIp[ipCounter]
A bit of research shows OSC uses UDP protocol. You might try a broadcast.
IPAddress outIp(192, 168, 1, 255);
