OSC receive code
Hello,
I want to receive 6 values from one arduino to an other ( UNO ) via OSC.
I use the new library OSC class compatible with Arduino021 from recotana.
My main concern is how to receive the data.
for example :
with this address :
Top address : /main Sub address : /1
My idea is to receive each 6 values and assign to send each a diffrent midi note .
I did not success to code the receive.
Thanks
OK.
via OSC.
Why?
Yeah, I see that.
Did you success to code the send?
Maybe show what you wrote, even if it didn't work.
Top address : /main Sub address : /1 My idea is to receive each 6 values and assign to send each a diffrent midi note .
You simply make the protocol up. Does the sub address have to be /1 if so then have a sub sub address as the channel number and the final value as the note if channel 3 needs to send MIDI note 48 then the message would be:- /main/1/3/48
