OSX upload failure
got any idea???
Arduino: 1.6.1 (Mac OS X), Board: "Arduino Uno"
Sketch uses 1,030 bytes (3%) of program storage space. Maximum is 32,256 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 2,039 bytes for local variables. Maximum is 2,048 bytes.
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x00
Problem uploading to board. See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
enabled in File > Preferences.
Plz harlp
Not a mac user, but it looks like driver issue to me.
I would try http://www.arduino.cc/en/Guide/Troubleshooting#upload
Ran into this error too, with a board that worked fine before. Another Uno works fine too.
The troublesome Uno was mounted on an aluminium sheet with screws and those hexagonal spacer nuts. When mounted: trouble. When unmounted: works fine. On closer inspection I could see a bit of copper where the nut touches the Arduino Uno, so the laquer was damaged a bit. Insulated with some tape, and it now runs fine. So somehow this was an electrical problem.
