OTA network port not listed
hello,
I have some truble regarding OTA update :
It's regarding the list of avaible ports on Arduino IDE :
after flashing the chip i found the network port until i rerun the IDE. After that I lost my network Port.
If I keep my IDE Open and open another, the second IDE will not see the port, but I can continue to update thru OTA with the first IDE.
I use windows 10 and more than 10 chips... and only 6 are listed...
Do you have any idea please?
Hello
https://arduino-esp8266.readthedocs.io/en/latest/ota_updates/readme.html
"Note: If the OTA port does not show up, exit Arduino IDE, open it again and check if the port is there. If it is not, check your firewall and router settings. The OTA port is advertised using mDNS service. To check if the port is visible by your PC, you can use an application like Bonjour Browser."
