OTA programming with esp8266 and BH1750 light sensor
Hey everyone, sorry for the noob question I'm a complete beginner.
How can I upload the BH1750test sketch over the air using esp8266?
I have connected my esp8266 to the wifi and uploaded the basic blink sketch and it worked but I couldn't make the BH1750test sketch work within the BasicOTA sketch.
Basically I'm trying to merge BasicOTA and BH1750test sketches, can anyone help?
BasicOTA
#include <ESP8266WiFi.h>
#include <ESP8266mDNS.h>
#include <WiFiUdp.h>
#include <ArduinoOTA.h>
const char* ssid = "..........";
const char* password = "..........";
  Serial.println("Booting");
  WiFi.mode(WIFI_STA);
  WiFi.begin(ssid, password);
  while (WiFi.waitForConnectResult() != WL_CONNECTED) {
    Serial.println("Connection Failed! Rebooting...");
    delay(5000);
    ESP.restart();
  // Port defaults to 8266
  // ArduinoOTA.setPort(8266);
  // Hostname defaults to esp8266-[ChipID]
  // ArduinoOTA.setHostname("myesp8266");
  // No authentication by default
  // ArduinoOTA.setPassword("admin");
  // Password can be set with it's md5 value as well
  // MD5(admin) = 21232f297a57a5a743894a0e4a801fc3
  // ArduinoOTA.setPasswordHash("21232f297a57a5a743894a0e4a801fc3");
  ArduinoOTA.onStart([]() {
    String type;
    if (ArduinoOTA.getCommand() == U_FLASH)
      type = "sketch";
    else // U_SPIFFS
      type = "filesystem";
    // NOTE: if updating SPIFFS this would be the place to unmount SPIFFS using SPIFFS.end()
    Serial.println("Start updating " + type);
  ArduinoOTA.onEnd([]() {
    Serial.println("\nEnd");
  ArduinoOTA.onProgress([](unsigned int progress, unsigned int total) {
    Serial.printf("Progress: %u%%\r", (progress / (total / 100)));
  ArduinoOTA.onError([](ota_error_t error) {
    Serial.printf("Error[%u]: ", error);
    if (error == OTA_AUTH_ERROR) Serial.println("Auth Failed");
    else if (error == OTA_BEGIN_ERROR) Serial.println("Begin Failed");
    else if (error == OTA_CONNECT_ERROR) Serial.println("Connect Failed");
    else if (error == OTA_RECEIVE_ERROR) Serial.println("Receive Failed");
    else if (error == OTA_END_ERROR) Serial.println("End Failed");
  ArduinoOTA.begin();
  Serial.println("Ready");
  Serial.print("IP address: ");
  ArduinoOTA.handle();
BH1750test
#include <BH1750.h>
#include <Wire.h>
BH1750 lightMeter;
  // Initialize the I2C bus (BH1750 library doesn't do this automatically)
  Wire.begin();
  // On esp8266 you can select SCL and SDA pins using Wire.begin(D4, D3);
  // For Wemos / Lolin D1 Mini Pro and the Ambient Light shield use
  // Wire.begin(D2, D1);
  lightMeter.begin();
  Serial.println(F("BH1750 Test begin"));
  float lux = lightMeter.readLightLevel();
  Serial.print("Light: ");
  Serial.print(lux);
  Serial.println(" lx");
what problem do you have with adding ArduinoOTA to your sketch?
I don't know how to modify the BasicOTA code to include BH1750test code. How can I include the BH1750test sketch in the Basic OTA code?
include OTA in your sketch
don't know how to merge these codes properly, I'm a complete beginner
@ertnnc
Are the two sketches working separately for you?
Why have you chosen different serial speeds?
I didn't choose anything, these are library sketches, first one is to connect the esp8266 to wifi, second one is for the bh1750 sensor, to upload the bh1750 sketch over the air I need to include BasicOTA code too, so I have to merge them, but I don't know how to
@ertnnc
You have posted two sketches and asked for help to combine them.
One has 9600 - the other has 115200 Serial baud.
When I tell you, that you can't combine easily two different baudrates on one Serial - what is your prefered baud rate? - You have to choose!
Furthermore I kindly ask you to answer all my questions:
ah sorry, 9600 is the preferred baud rate, and yes the sketches are working separately
you need to:
put all things from global to global
put all things from setup to setup
put all things from loop to loop.
As you can't (shouldn't) block your code with a delay, you need something like it is explained in the example "Blink without delay".
I would use a separate function for the sensor and its timing.
untesteted based on the two codes you gave:
#include <BH1750.h>
#include <Wire.h>
BH1750 lightMeter;
void sensorHandle()
  uint32_t currentMillis = millis();
  static uint32_t previousMillis = 0;
  if (currentMillis - previousMillis > 1000) // replace delay by "Blink without Delay" non blocking code
    Serial.print(lux);
    delay(5000);
    ESP.restart();
    String type;
      type = "sketch";
    else // U_SPIFFS
  ArduinoOTA.begin();
  Wire.begin();
  lightMeter.begin();
  sensorHandle();
thank you so much it worked :slight_smile:
