OTA udate problem due to delay function
Dear experts
I completed my first Arduino/ESP32 project and it works so far to my satisfaction. I intend now to include the OTA Update function. Here I get the interference with my sketch below.
In order to make the scrolling routine (displayed text on TFT) not too fast, I had to include a delay of 200(ms) quite at the end of my code below. This however prevents the ArduinoOTA.handle() from working correctly. As soon as I get rid of the delay (3rd last line) all works fine but of course the scrolling text is displayed way too fast.
I am aware that I need to avoid the delay function in order to make OTA work, but how can I rewrite the scrolling routine to avoid the 200ms delay function in order to make ArduinoOTA.handle() work?
As I obviously will have to change the code anyway I also consider to completely rewrite the routine as an other option. In my project the text "scrolls" letter by letter. Is there a way I could make the scrolling text scrolling smooth lets say e.g. pixel by pixel and of course working with ArduinoOTA.handle()?
Thanks alot for helping me newby.
  ArduinoOTA.handle(); // OTA Job
  //Scroll Routine
  String text = (furtherstops[furtherstops_id]);
  const int width = 14; // width of the marquee display (in characters)
  // Loop once through the string
  for (int offset = 0; offset < text.length(); offset++)
    // Construct the string to display for this iteration
    String t = "";
    for (int i = 0; i < width; i++)
      t += text.charAt((offset + i) % text.length());
    if (scroll_renew == (true))
      scroll_renew = (false);
      offset = (text.length());
      tft.fillScreen(ST7735_WHITE);
    // Print the string for this iteration
    tft.setCursor(20, 74); // display position
    delay(200);    // Short delay so the text doesn't move too fast
    tft.print(t);
Untested
  unsigned long currentTime = millis();
  static unsigned long previousScrollTime = currentTime;
  const unsigned long scrollPeriod = 200;
    previousScrollTime = currentTime; //save for next time
    //Scroll Routine
      String t = "";
      //delay(200);    // Short delay so the text doesn't move too fast
      tft.print(t);
Or the obvious, instead of the delay() use millis() and call ArduinoOTA.handle(); repeatedly while you wait.
uint32_t moment = millis();
while (millis() - moment < 200) {
  yield();
as always, great support. Thank you both very much indeed. I understand now the concept of how to avoid delay()
