Hi
I've been experimenting with updating my server code OTE but have had little success.
I have a W5500 adapter and Blue/Blackpills available.
I have the basic server code (without OTE updating) running nicely on a Nucleo 64 STM32F401 and am now attempting to port it over to a Bluepill - I have some Blackpills coming as I suspect the Bluepill 32k of flash isn't enough to support even the most basic of OTE / server,
I know how to load blinky using my ST-Link/V2 programmer and I expect to use that to load my OTE code in the target 'pill' - although currently I'm a little confused about boot loaders and usb port on the pill.
I've tried Juraj's most excellenent libraries and they worked great for OTE on my Mega2560. However in 'myboards' I don't see an option for the Blackpill F411.
I've googled but not found a solution - maybe someone here can point me in the right direction for an example or starting opoint ?
After a bit more searching I came across this thread
which got me going and can now see an IP being allocated.
Still need to make sure it's working ok and have the boot jumpers on the right place etc., but at least it now has a 'pulse'.
thanks for taking the time to reply - much appreciated.
I have a simple websever with OTE running ok, but am having a problem finding where to place your new platform.local.txt file.
I'm running windows 10 and I have two versions of the IDE installed 1.8 and 2.2 but now only use 2.2 which starts in C:\Users\tim\AppData\Local\Programs\arduino-ide\ with "C:\Users\tim\AppData\Local\Programs\arduino-ide\Arduino IDE.exe" but doesn't have a packages folder. So I'm not sure where version looks for its folders etc.
Any ideas ?
Thanks Tim
Where version 1.8 starts in "C:\Program Files (x86)\Arduino\arduino.exe" and holds all the usual IDE folders
Everything works fine for the mega2560 version of the code - including OTE updates with password
Ok, Ive done as suggested above and also added an entry into programmers.txt - but the board still does not show as a programming port - whereas my Mega2560 does.
Using Wireshark I can see my Mega2560 doing its MDNS thing but the bluepill doesn't appear to be advertising its port using MDNS. Maybe I have a library issue ?
Edit it is doing MSDS, just not very often
Here's the code I'm using - I flash a LED to make sure it's running and to detect if it's been updated as I chnaged the speed of the flash.
// generic stm32F1 series
#include <SPI.h>
#include <Ethernet.h>
//#define NO_OTA_PORT
#include <ArduinoOTA.h>
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xBB, 0x06 };
int reqCount = 0; // number of requests received
EthernetServer server(80);
//Initialize serial:
while (!Serial);
// start the Ethernet connection:
Serial.println("Initialize Ethernet with DHCP:");
if (Ethernet.begin(mac) == 0) {
Serial.println("Failed to configure Ethernet using DHCP");
Serial.print(" DHCP assigned IP ");
Serial.println(Ethernet.localIP());
// start the OTEthernet library with internal (flash) based storage
ArduinoOTA.begin(Ethernet.localIP(), "Arduino", "password", InternalStorage);
pinMode(LED_BUILTIN, OUTPUT);
// check for updates
ArduinoOTA.poll();
digitalWrite(LED_BUILTIN, HIGH); // turn the LED on (HIGH is the voltage level)
delay(1000); // wait for a second
digitalWrite(LED_BUILTIN, LOW); // turn the LED off by making the voltage LOW
// add your normal loop code below ...
if (client)
Serial.println(F("New client"));
// an http request ends with a blank line
bool currentLineIsBlank = true;
while (client.connected())
if (client.available())
char c = client.read();
if (c == '\n' && currentLineIsBlank)
Serial.println(F("Sending response"));
client.print(
"HTTP/1.1 200 OK\r\n"
"Content-Type: text/html\r\n"
"Connection: close\r\n" // the connection will be closed after completion of the response
"Refresh: 20\r\n" // refresh the page automatically every 20 sec
"\r\n");
client.print("<!DOCTYPE HTML>\r\n");
client.print("<html>\r\n");
client.print("<h2>Hello World from ");
client.print(BOARD_NAME);
client.print("!</h2>\r\n");
client.print("Requests received: ");
client.print(++reqCount);
client.print("<br>\r\n");
client.print("Analog input A0: ");
client.print(analogRead(0));
client.print("</html>\r\n");
if (c == '\n')
// you're starting a new line
else if (c != '\r')
// you've gotten a character on the current line
currentLineIsBlank = false;
// give the web browser time to receive the data
delay(10);
// close the connection:
client.stop();
Serial.println(F("Client disconnected"));
for programmer.ttx reload, IDE 1 needs restart.
in IDE 2 the programmers.txt is cached forever. stop the IDE and delete .arduinoIDE in your home folder
I did as you suggested, but still no port showing for the Bluepill within the IDE - but I do see ports for my other ota devices (two atmega2560 and a ESP8266 wifi node)
I've obviously messed up, interestingly when I do an IP scan the bluepill shows as having a HTTP server available (which works fine) but the other OTA devices which also run servers do not show as being available even though they work fine.
I'll work on this little more by myself and report back if I manage to sort it out.
Thanks for that info - I've disabled the serial port just for good measure and when I came to upload the code it asked for a password for the first time before uploading via ST-link but still no port showing in the ide.
I think I'll start over tomorrow with a brand new blackpill having deleted the .ide in my home directory first.
I guess you've probably got more important stuff to do than helping a newbie like me, so only asking as a last resort - enjoy your coffee
Just to close this off - I started a fresh and rebuilt the code making sure it was aimed at the right board and since then everything has been fine !
Thanks Juraj for your time and great libraries !
