Other ATmegas (or ATtinys to)
Hello,
wouldn't it be possible to make a bootloader for other ATmegas then the 168/328/1280/2560? Perhaps even some ATinys? You could burn the bootloader with ISP and download the sketches with the FDTI cable. It doesn't need to be a new board for every ATmega/tiny, just a bootloader available.
This would make it much more economical to build projects what one need a few Inputs/Outputs, or many Inputs/Outsputs with only one chip. Or use features like the onboard Can interface of some ATmegas.
Jan
Yes, it would.
Search the forum for examples of people having done just that.
I can't find any, just topics like mine, what should I search for?
But: I thought more of official bootloaders for other chips what you can burn from the arduino IDE. I'm not so much into Hex files and so, but I have managed to burn a bootloader on another ATmega328 from the Arduino IDE.
Jan
http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1281994270/4
That link seemed pretty good. So you just burn the arduino bootloader
from the IDE onto the chip to be burned? What board should I pick?
Jan
you will need to modify boards.txt
and not all of them can use a boot loader, for example most tiny's do not have a boot loader available, so you need an ISP programmer, which can be an arduino
I have looked into boards.txt but what do I need to change?
Do you mean not all of the ATmegas/tinys in zachwiejs list can use the bootloader?
Yea, I had the idé to use my arduino to do the ISP programming.
Jan
