Other module wont work after SD Card init
void setup(){
Serial.println(F("TEST FUNCTION"));
#ifdef LED
pinMode(LED, OUTPUT);
digitalWrite(LED, LOW);
#endif
pinMode(FONA_RST, OUTPUT);
digitalWrite(FONA_RST, HIGH); // Default state
pinMode(FONA_PWRKEY, OUTPUT);
powerOn(); // Power on the module
moduleSetup(); // Establishes first-time serial comm and prints IMEI
fona.setFunctionality(1); // AT+CFUN=1
fona.setNetworkSettings(F("hologram")); //
fona.setPreferredMode(38); // Use LTE only, not 2G
fona.setPreferredLTEMode(1); // Use LTE CAT-M only, not NB-IoT
fona.setOperatingBand("CAT-M", 12); // AT&T uses band 12
if (!fona.enableGPRS(false)) Serial.println(F("Failed to disable GPRS!"));
// Turn on GPRS
while (!fona.enableGPRS(true)) {
Serial.println(F("Failed to enable GPRS, retrying..."));
delay(2000); // Retry every 2s
Serial.println(F("Enabled GPRS!"));
Serial.println("Initializing SD card...");
if (!SD.begin(SD_CS)) {
Serial.println(F("initialization failed!"));
while (1);
Serial.println(F("initialization done."));
in the above code, nothing works after initializing SD card. I get the initialization done message but after that the system stop communicating with the sim7000 module. It sends AT commands but doesnt receive any replies, none of the GET/POST request work either. If i comment the SD card initialization, everything works normal. What i am missing? Something to do with SPI communication ?
Is the SD card module a separate part (not part of the SIM7000)? If so which one?
Its different. Its from adafruit. Link to the module:
initialize SD card first
Found the issue. The SIM7000 uses software serial at pins 10 and 11, so they were clashing with the SPI on the sd card. Changed the software serial to pins 8 and 9. works smooth now.
Thanks for sharing your solution ammarqs.
ammarqs:
isn't it something you should see when you wire it?
