Outdoor Light Sensing controller
Hey everyone! I have found this forum very helpful but I have a few questions on how to go about doing a project for a family member!
I am wanting to make a setup with an arduino board that turns on a cluster of LEDs dependent on the ambient light.
Example: (those little garden lights you see outside that come on at night)
Which is what I want it to exactly do but instead of converting solar light to power the lights I will use a larger battery cell to power the efficient LEDs.
So what would be the best route to make this feasible?
Would I need photodiodes? or something similar?
I really would appreciate the help!
If all you want to do is to switch on the lights once it is getting dark, you will not need microcontroller at all.
Check out this for example:
http://www.evilmadscientist.com/article.php/nightlight
Hope that helps :slight_smile:
For the ambient light sensing, a simple LDR (Light Dependent Resistor) plus a 10K resistor to an Arduino Analog input would let you set the light level you want..
Example: http://arduino-direct.com/sunshop/index.php?l=product_detail&p=135
DISCLAIMER: I mentioned stuff from my own Shop...
