Outdoor Split Core Current Transformer Waterproof
Hello!
I need a outdoor split core current transformer waterproof, like SCT-013-005.
Any suggestion?
Thanks!
pablopf16:
Hello!
Any suggestion?
Thanks!
Yes,, I suggest you use Google to search for SCT-013-005 and look at all the images he gives you . There are a bunch of split cores units that appear to be water RESISTANT.
Paul
If you can why not put it in a waterproof electrical enclosure, they are not that expensive. The plug will be your biggest problem over time it would be best if it were directly connected.
Paul_KD7HB:
Paul
Thanks Paul
gilshultz:
Thanks for your answer.
My initial idea was to have the microcontroller in a waterproof electrical enclousure and the sensor in the outdoor to measure the current of an electric fence.
You need IP66, IP67 or IP68 in your search string...
pablopf16:
Are you referring to the current going to the control unit? The HIGH VOLTAGE current going to an electric fence is zero unless it is shorted to ground somewhere.
Paul
MarkT:
Thanks but not my question
Paul_KD7HB:
Paul
In my tests, the current was not 0, but very low.
pablopf16:
Do you know the meaning of IP66, IP67 or IP68? Because it's pretty much exactly what you're asking for...
pablopf16:
That is the way it should be. Your fence is a CAPACITOR. The HV is charging a capacitor. You need to use an oscilloscope to see the charging current. IT will be a very short pulse.
Paul
wvmarle:
If you don't want to help, don't comment. Obviously I have googled. I am looking for someone who has had some experience with a sensor. It is the third post that I receive with the same comment.
