Merry Christmas to all,
I'm creating a digital thermometer (up to 1000 degrees Celsius) and I want to output on the screen the temperature per fives e.g. 155, 160, 165, 170 etc.
Any idea of how can I do that ?
thank you in advance.
Hi John,
it is time for you to really start learning programming.
Take a look into this tutorial:
It is easy to understand and has a good mixture between explaining important concepts and example-codes to get you going. So give it a try and report your opinion about this tutorial.
Your question could be interpreted as a diplomatic hidden way of asking
"can somebody post the ready to use code to ..."
Your question is way too unprecise:
You should write:
Does your question include how to measure temperatures up to 1000 degrees?
This is your post #8 in post #1 you have been told to read thorugh this page
https://forum.arduino.cc/index.php?topic=712201.0
you should really do it!
best regards Stefan
if ((temperature % 5) == 0)
//print the temperature
StefanL38:
Hi John,it is time for you to really start learning programming.
Take a look into this tutorial:It is easy to understand and has a good mixture between explaining important concepts and example-codes to get you going. So give it a try and report your opinion about this tutorial.
"can somebody post the ready to use code to ..."Your question is way too unprecise:
You should write:
- which arduino-board are you using
- what kind of screen? if it is some special screen provide a link to the datasheet and the documentation of this screen
How to get the best out of this forum - Programming Questions - Arduino Forumyou should really do it!
best regards Stefan
StefanL38:
You should write:
best regards StefanDear Stefan, thank you very much for your suggestions (really thank you) but a simple reply like what "UKHeliBob" did (below) is what I needed!
UKHeliBob:
thank you very much sir, I appreciate that.
