Having trouble integrating programs. One measures capacitance and outputs the manipulated value on serial monitor. The other uses analog input data to trigger DIO. I am trying to use the output data to trigger a digital output pin, but having trouble understanding how the variables are being manipulated in the first part:
Preformatted text
#include <Wire.h>
#include <Protocentral_FDC1004.h>
#define UPPER_BOUND 0X4000 // max readout capacitance
#define LOWER_BOUND (-1 * UPPER_BOUND)
#define CHANNEL 0 // channel to be read
#define MEASURMENT 0 // measurment channel
int capdac = 0;
char result[100];
FDC1004 FDC;
Wire.begin(); //i2c begin
Serial.begin(115200); // serial baud rate
FDC.configureMeasurementSingle(MEASURMENT, CHANNEL, capdac);
FDC.triggerSingleMeasurement(MEASURMENT, FDC1004_100HZ);
//wait for completion
delay(15);
uint16_t value[2];
Serial.println(uint16_t value[2]);
if (! FDC.readMeasurement(MEASURMENT, value))
int16_t msb = (int16_t) value[0];
int32_t capacitance = ((int32_t)457) * ((int32_t)msb); //in attofarads
capacitance /= 1000; //in femtofarads
capacitance += ((int32_t)3028) * ((int32_t)capdac);
Serial.print((((float)capacitance/1000)),4);
Serial.print(" pf, ");
if (msb > UPPER_BOUND) // adjust capdac accordingly
if (capdac < FDC1004_CAPDAC_MAX)
capdac++;
else if (msb < LOWER_BOUND)
if (capdac > 0)
capdac--;
