Output current 5 volts
Hello, want to do a project with WS2812B leds. A led of this type consumes 0.018 Ampere and I would like to put 76 and I don't know if the 5 volt output will be able to supply them all and if not, what should I do?
That will be almost 1A total which will exceed the output rating of most controllers (you did not specify what board you are using). If this is just on/off, you would use a relay with a power supply capable of a 1A load.
There are 3 LEDs per pixel.
I use an arduino nano and a power supply by USB C of 1.67A for the card even with that it will not work?
You will need to do something like this:
For reference: How to Control WS2812B Addressable RGB LEDs using Arduino
Power the strip like this.
No it will not.
The maximum current draw for a WS2812B is about 0.056A.
76 of them would need 76 x 0.056A = 4.26A @5V
A 5V, 5Amp supply will be OK
so I have to buy a 5v and 5a power supply and a capacitor
this is good?
Alimentation Adaptateur Dc 5v 6v 8v 9v 10v 12v 13v 14v 15v 24v Chargeur Universel 1a 2a 3a 5a 6a 8a Transformateur 220v 12v Chargeur Switch For Overboard - Alimentation À Découpage - AliExpress
I don't know anything about the quality of the product.
The 5V 5A or 6A model would be good
ok thanks
You need 5V with at-least 5A of current capability.
The voltage needs to be constant and then the actual current will depend on how many LEDs are on at any given time. i.e. With noting connected 5V is present but no current flows.
...I don't trust "cheap stuff" from AliExpress, eBay, or 3rd-party Amazon suppliers, etc. You'll probably be OK but I like to buy from reputable electronics suppliers, and most of what thyey sell is from known-reputable manufacturers. I might cost more, but you get good stuff and usually you get a link to the datasheet or other important documentation.
Here in the U.S., Mouser, Digikey, Jameco, SparkFun, and Adafruit are all good. A lot of electronic manufacturer's buy components from Mouser and Digikey. Mouser doesn't have a minimum order and I buy from them a lot.
ok and the capacitor must also be 5v?
thanks and the capacitor must also be 5v?
Suggest your capacitor be rated at 10v or more.
The value can be 470uF to 1000.
The capacitor should 10V or more
PLEASE DO NOT CROSS POST EVEN ACROSS LANGUAGES
Cross-posting is against the Arduino forum rules. The reason is that duplicate posts can waste the time of the people trying to help. Someone might spend a lot of time investigating and writing a detailed answer on one topic, without knowing that someone else already did the same in the other topic.
Please create one topic only for your question and choose the forum category carefully. If you have multiple questions about the same project then please ask your questions in the one topic as the answers to one question provide useful context for the others, and also you won’t have to keep explaining your project repeatedly.
Repeated duplicate posting could result in a temporary or permanent ban from the forum.
Could you take a few moments to Learn How To Use The Forum. It will help you get the best out of the forum in the future.
Thank you.
