Output current AVR lower with PORTB = _BV(0); then with digitalWrite(9, HIGH); ?
Hi, How come my LED shines less light when I use basic bit PORTB = _BV(0); then when I use digital write(like in below examples)? Arduino code:
  pinMode(9, OUTPUT);
Basic C output:
#define DDRB 0xFF
int main() {
PORTB = _BV(0);
When I measure the voltage over the LED + Resistor when using digitalWrite, the total voltage is 5v, but with the C operation there is no voltage over the resistor.
Does this work any differently...
int main() {
PORTB = _BV(0);
Ezraneut: Basic C output:
#define DDRB 0xFF
int main() { PORTB = _BV(0); }
This code doesn't seem to set the pin for OUTPUT.
...R
Robin2:
#define DDRB 0xFF
...R
Is it in the #define? So when I say DDRB = 0xFF, does it work? I will check this evening at home.
jep, that was it. Solved.
int main() {
DDRB = 0xFF;
while(1){
PORTB = _BV(0);
