Hi, I'm new to using Arduino.
I am trying to interface arduino mega2560 with Texas instrument’s ECG Analog Front End ADS1293. I'm using code from GitHub - srivera1/ECG: ECG with an ads1293 adc and arduino.
After running the program on the Arduino IDE the results I get are 0 on the serial monitor and serial plotter.
Can you help me in debugging the code? What should I do to fix the problem? I've also adjusted to the ads1293 datasheet from TI
This is the code i have used:
SPI conection:
ads1293 Mega2560
Power 3,3V 3,3V //pin keempat atas
GND GND // Pin 2 dan 3 dari bawahnya, selang 1 dengan 3,3V
SCLK D52 //pin kesatu dalam
SDI D51 (slave in - master out) //pin kedua luar
SDO D50 (slave out - master in ) //pin kedua dalam
CSB D53 //pin kesatu luar
ALARMB -
DRDYB D6 //pin kedua di arduino
#include <SPI.h>
const int pin_DRDYB = 6; // data ready
const int pin_SS = 53; // CSB
const unsigned long int ADCmax=0x800000;
pinMode(pin_DRDYB, INPUT);
pinMode(pin_SS, OUTPUT);
Serial.begin(9600); // (less than 115200 will decimate the signal -> de facto LPF)
SPI.begin();
setup_ECG();
int32_t ecgTmp = 0;
int32_t ecgTmp2 = 0;
if (digitalRead(pin_DRDYB) == false) {
int32_t ecgVal;
// sampled data is located at 3 8-bit registers
byte x1 = readRegister(0x37);
byte x2 = readRegister(0x38);
byte x3 = readRegister(0x39);
// 3 8-bit registers combination on a 24 bit number
ecgVal = x1;
ecgVal = (ecgVal << 8) | x2;
ecgVal = (ecgVal << 8) | x3;
// exponential smoothing as LPF
// 1) short range smoothing
ecgTmp = ecgTmp * .5 + ecgVal * .5;
// 2) Baseline
ecgTmp2 = ecgTmp2 * .90 + ecgVal * .10;
Serial.println(ecgTmp - ecgTmp2);
void setup_ECG() { // datasheet ads1293
//Follow the next steps to configure the device for this example, starting from default registers values.
//1. Set address 0x01 = 0x11: Connect channel 1’s INP to IN2 and INN to IN1.
writeRegister(0x01, 0x11);
//2. Set address 0x02 = 0x19: Connect channel 2’s INP to IN3 and INN to IN1.
writeRegister(0x02, 0x19);
//3. Set address 0x0A = 0x07: Enable the common-mode detector on input pins IN1, IN2 and IN3.
writeRegister(0x0A, 0x07);
//4. Set address 0x0C = 0x04: Connect the output of the RLD amplifier internally to pin IN4.
writeRegister(0x0C, 0x04);
//5. Set address 0x12 = 0x04: Use external crystal and feed the internal oscillator's output to the digital.
writeRegister(0x12, 0x04);
//6. Set address 0x14 = 0x24: Shuts down unused channel 3’s signal path.
writeRegister(0x14, 0x24);
//7. Set address 0x21 = 0x02: Configures the R2 decimation rate as 5 for all channels.
writeRegister(0x21, 0x02);
//8. Set address 0x22 = 0x02: Configures the R3 decimation rate as 6 for channel 1.
writeRegister(0x22, 0x02);
//9. Set address 0x23 = 0x02: Configures the R3 decimation rate as 6 for channel 2.
writeRegister(0x23, 0x02);
//10. Set address 0x27 = 0x08: Configures the DRDYB source to channel 1 ECG (or fastest channel).
writeRegister(0x27, 0x08);
//11. Set address 0x2F = 0x30: Enables channel 1 ECG and channel 2 ECG for loop read-back mode.
writeRegister(0x2F, 0x30);
//12. Set address 0x00 = 0x01: Starts data conversion.
writeRegister(0x00, 0x01);
byte readRegister(byte reg) {
byte data;
reg |= 1 << 7;
digitalWrite(pin_SS, LOW);
SPI.transfer(reg);
data = SPI.transfer(0);
digitalWrite(pin_SS, HIGH);
return data;
void writeRegister(byte reg, byte data) {
reg &= ~(1 << 7);
SPI.transfer(reg);
SPI.transfer(data);
//// convert ADC value to Volt:
//// Read page 36 by finding (VINP-VINM). in case ADC_max = 0x8000 the formula will be:
////////(VINP-VINM) = ADC_out / 6116.69333333 - 685.71;
