Output going high when told to go low and vice versa
I hate to bother everyone, but I have tinkered with the code and hardware for 3 days now and am about ready to pull my hair out.
Background: The project is a temperature control unit. When the temp reaches the set point +differential the unit should output a signal to an SSR, which in turn turns on the 110V mains. The freezer cools and when the sensor reaches set point-differential the output should turn off.
Problem: 1. Output "A4" is doing the opposite of what I would expect it to do. When the temp is low, the output is on. When the temp is high the output is off. I have simulated the SSR with a led and get the same behavior. I have tried different pins, same behavior. I have a led on pin "9" that indicates freezer is "On". This output is behaving correctly. 2. The buttons function poorly. By poorly I mean I may have to press the buttons multiple times to increase/decrease 1 unit. If I disconnect the temp sensor, the buttons perform much better. I am positive this is due to shoddy programming.
Any help would be greatly appreciated. Problem 1 is my main focus, but any input on problem 2 would be great. Don't go easy on me, I know I am a weak programmer, as this is a hobby for me.
Thanks,
#include <OneWire.h>
#include <DallasTemperature.h>
// Data wire is plugged into port 2 on the Arduino
#define ONE_WIRE_BUS 4
#define TEMPERATURE_PRECISION 12
OneWire oneWire(ONE_WIRE_BUS);
DallasTemperature sensors(&oneWire);
uint8_t therm1[8], therm2[8];
int heatcoolswitch = 8;
int freezer = A4;
int setpoint = 65;
int diff = 2;
int setpointbutton = 13;
int diffbutton = 12;
int upbutton = 10;
int downbutton = 11;
int led = 9;
int valsp = 0;
int valdiff = 0;
int valup = 0;
int valdown = 0;
int prevvalsp = 0;
int prevvaldiff = 0;
int prevvalup = 0;
int prevvaldown = 0;
unsigned long lastBtnUp = 0;
unsigned long lastBtnDwn = 0;
unsigned long lastBtnSP = 0;
unsigned long lastBtnDiff = 0;
int transInt = 30;
int Turnon = 0;
int Turnoff = 0;
void setup(void)
  pinMode(freezer, OUTPUT);
  digitalWrite(freezer, LOW);
  pinMode(setpointbutton, INPUT);
  digitalWrite(setpointbutton, HIGH);
  pinMode(diffbutton, INPUT);
  digitalWrite(diffbutton, HIGH);
  pinMode(upbutton, INPUT);
  digitalWrite(upbutton, HIGH);
  pinMode(downbutton, INPUT);
  digitalWrite(downbutton, HIGH);
  pinMode(led, OUTPUT);
  digitalWrite(led, LOW);
  Serial.print("?c0");
  sensors.begin();
  sensors.getDeviceCount();
  sensors.getAddress(therm1, 0);
  sensors.setResolution(therm1, 12);
  Serial.print("?f");
  Serial.print("?x00");
  Serial.print("?y0");
  Serial.print("?C0  Temperature   ");
  delay(200);
  Serial.print("?C1Monitoring Unit ");
  delay(200);
  Serial.print("?S2");
  Serial.print("?f");
void spset()
valup = digitalRead(upbutton);
valdown = digitalRead(downbutton);
     if (valup == HIGH && prevvalup == LOW)
            {if (millis() - lastBtnUp > transInt)
            ++setpoint;
           lastBtnUp = millis();}
           prevvalup = valup;
     if (valdown == HIGH && prevvaldown == LOW)
            {if (millis() - lastBtnDwn > transInt)
            --setpoint;
           lastBtnDwn = millis();}
           prevvaldown = valdown;
void diffset()
            ++diff;
           prevvalup = valup;
            --diff;
void printTemperature(uint8_t deviceAddress[])
  float tempF = sensors.getTempF(deviceAddress);
  Serial.print("?x09");
  Serial.print(tempF);
  Serial.print("F");
  Serial.print("?y1");
  Serial.print("SP=");
  Serial.print(setpoint);
  Serial.print(" ");
  Serial.print("?x06");
  Serial.print("Diff=");
  Serial.print(diff);
  Serial.print("  ");
void tempcontrol(uint8_t deviceAddress[])
  Turnon = setpoint + diff;
  Turnoff = setpoint - diff;
  if (tempF > Turnon)
  digitalWrite(freezer, HIGH);
  digitalWrite(led, HIGH);
  if (tempF < Turnoff)
void loop(void)
  sensors.requestTemperatures();
  Serial.print("Sensor 1");
  printTemperature(therm1);
  tempcontrol(therm1);
  valsp = digitalRead(setpointbutton);
  if (valsp == HIGH)
     {if (millis() - lastBtnSP > transInt)
       prevvalsp = valsp;
       spset();
      lastBtnSP = millis();}
  valdiff = digitalRead(diffbutton);
  if (valdiff == HIGH)
     {if (millis() - lastBtnDiff > transInt)
       prevvaldiff = valdiff;
       diffset();
     lastBtnDiff = millis();}
When you say you have an LED on a pin, how is it wired?
To 5V or to ground?
The led is wired to ground via a limiting resistor. I thought the same thing.
This is using pin 13 as an input pin. That is the pin with the built in LED and resistor. It's generally not recommended to use this as an input pin.
Putting { and } on separate lines, and using Tools + Auto format would greatly improve the readability of your code.
What do these contribute? What is the serial output going to?
PaulS,
I will work on the formatting. The serial output is going to a 2X16 lcd display. It has been awhile since I wrote that portion of the code, so I can't off hand say what those lines are doing. I am using a RBBB from modern device, that does not have the led on pin 13. I will get off that pin and see what it does for me.
Thanks
For debugging purposes, I'd unplug that LCD, and use the Serial Monitor. You can print a lot more information to the serial monitor than you can to the LCD.
It would also be worthwhile to try the code on a real Arduino to see if it exhibits the same behavior.
