Output Low While Switch Gear
Hello everyone. I am in the process of programming a tiptonic shifter for my vehicle. I am figuring out most of it while I go but I have searched and searched and now I have no idea how to make this happened.
This is the operation I currently have functioning:
output "ctrlSolenoid[2]" will be HIGH if "solenoidPin[2]" is HIGH or "TorqCnvtr_Switch_iPIN" is HIGH.
What I want to add:
I have created a boolean "blnTorqLockEnable". My goal is that when int GearOutput is changed (either by the intGear switch or Auto Pass Through Mode (blnManualShift true or false)) then "blnTorqLockEnable" would be false for "x" amount of seconds to allow the shift. Almost like a clutch in a manual car.
The section of code referenced above can be found in void GearBox starting on line 162.
// LIBRARIES ---------------------------------------------------v
#include <Bounce.h>
// CONFIGURATION -----------------------------------------------v
// tachometer
const int INT_FrontPulsesPerRev = 16;	// Front sensor pulses per revolution
const int INT_RearPulsesPerRev = 4;		// Rear sensor pulses per revolution
const unsigned long ULNG_SamplingMS = 250;
// Torque Converter Lock Momentary disengaging time in milliseconds
const unsigned long ULNG_TorqLockDisableT = 1000;
// inputs
const int FrontSensor_iPIN = 2;
const int TorqCnvtr_Switch_iPIN = 13;
// outputs
const int RearSensor_oPIN = 12;
const int btnPin[] = { A2, A1, A0 };
// Up, Down, Mode
long btnDebounces[] = { 0, 0, 0 };
// -> CurrentState, LastState
int buttonStates[3][2] = { {LOW, LOW},
                           {LOW, LOW},
                           {LOW, LOW} };
// A, B, TCC
int solenoidStates[3] = { LOW, LOW, LOW };
const int ctrlSolenoid[] = { 6, 7, 5 };
const int solenoidPin[] = { A4, A5, A3 };
long debounceDelay  = 20;    // the debounce time; increase if the output flickers
// gear ratios
const float FLT_GearRatios[] =
{ 0.3571, 0.6535, 1.0000, 1.3333 };
// VARIABLES AND OBJECTS ---------------------------------------v
unsigned long ulngTachCounter = 0;
unsigned long ulngTachTS = 0;
float fltFrontFrequency;
float fltRearFrequency;
int intGear;
int intGearNumber;
boolean blnTorqLockEnable = true;
float fltGearRatio;
unsigned long ulngTorqLockDisable = 0;
unsigned long ulngRearSensorTS = 0;
boolean blnRearSensorState = false;
unsigned long ulngRearTHalfus;
boolean blnManualShift = false;
// DEBUG
const boolean blnDBG = true;
unsigned long ulngDBGTS = 0;
	// Configure Pins
	ConfigurePins();
	// Start in Auto Shift Mode, Gear at 1st, Torque Converter Lock off
	intGear = 1;	// first gear is zero
	intGearNumber = 1;
	// Read Shifting, Auto/Man and Torque Lock Buttons, Change Gears and Manage Solenoids
	GearBox();
void GearBox() {
    for (int btn = 0; btn < 3; btn++) {
    int reading = digitalRead(btnPin[btn]);
    if (reading != buttonStates[btn][1]) { // last button state
      btnDebounces[btn] = millis();
    if ((millis() - btnDebounces[btn]) > debounceDelay) {
      if (reading != buttonStates[btn][0]) {
        buttonStates[btn][0] = reading;
        // only toggle the LED if the new button state is HIGH
        if (reading == HIGH) {
          switch(btn) {
            case 0: // Up
              intGear = GearOutput();
              blnManualShift = true;
              intGear++;
              if (intGear > 4) intGear = 4;
              Serial.write("UP\n");
            case 1: // Down
              intGear--;
              if (intGear < 1) intGear = 1;
              Serial.write("DOWN\n");
            case 2: // Mode
              blnManualShift = !blnManualShift;
              Serial.write("MODE\n");
    buttonStates[btn][1] = reading;
  switch (intGear) {
    case 1:
      digitalWrite(ctrlSolenoid[0], HIGH);
      digitalWrite(ctrlSolenoid[1], LOW);
    case 2:
      digitalWrite(ctrlSolenoid[1], HIGH);
    case 3:
      digitalWrite(ctrlSolenoid[0], LOW);
    case 4:
        //AUTO Pass Through MODE
if (blnManualShift == false) {
            digitalWrite(ctrlSolenoid[0], digitalRead(solenoidPin[0]));
            digitalWrite(ctrlSolenoid[1], digitalRead(solenoidPin[1]));
	// Manage the torque lock
	//	while watching for gear changes
	// If Gear changed >> Torque Lock disabled for shifting
	if (GearOutput() != intGear) {
		ulngTorqLockDisable = millis();
		blnTorqLockEnable  = false;
	// Torque Lock re enabled after shift
	if ( msElapsed(blnTorqLockEnable) >  ULNG_TorqLockDisableT ) {
	//  Torque lock will go HIGH if Solenoid 3 input is HIGH or if the Torque Lock switch is ON. This only if the gear has not shifted.
	//	If it has shifted it would be temporarily disabled using the blnTorqLockEnable variable set to true when a change of gear was detected
        if (digitalRead(TorqCnvtr_Switch_iPIN) == HIGH && blnTorqLockEnable == true) {
          digitalWrite(ctrlSolenoid[2], HIGH);
        else {
          digitalWrite(ctrlSolenoid[2], digitalRead(solenoidPin[2]));
// TIMING FUNCTIONS
unsigned long msElapsed(unsigned long ulngTms) {
	// RETURNS THE MILLISECONDS ELLAPSED SINCE ulngTms
	return millis() - ulngTms;
unsigned long usElapsed(unsigned long ulngTus) {
	// RETURNS THE MICROSECONDS ELLAPSED SINCE ulngTus
	return micros() - ulngTus;
// SHIFTING FUNCTIONS
int GearOutput() {
	int intGearNumber;
	intGearNumber = 2*digitalRead(ctrlSolenoid[1]) + digitalRead(ctrlSolenoid[0]);
	switch(intGearNumber) {
	case 1:	// 1st Gear
		return 1;
	case 3:	// 2nd  Gear
		return 2;
	case 2:	// 3rd Gear
		return 3;
	case 0:	// 4th Gear
		return 4;
// SETUP FUNCTION
void ConfigurePins() {
  pinMode(btnPin[0], INPUT);
  pinMode(btnPin[1], INPUT);
  pinMode(btnPin[2], INPUT);
  pinMode(ctrlSolenoid[0], OUTPUT);
  pinMode(ctrlSolenoid[1], OUTPUT);
	pinMode(solenoidPin[2], INPUT);
	pinMode(TorqCnvtr_Switch_iPIN, INPUT);
	pinMode(FrontSensor_iPIN, INPUT);
	pinMode(ctrlSolenoid[2], OUTPUT);
	pinMode(RearSensor_oPIN, OUTPUT);
Any help is much appreciated.
Kris
I figured it out after reading over state change detection a few times. I forgot to update the state for the next time the through the loop.
So now when a gear is switched, "blnTorqLockEnable" Is false for the indicated amount of time.
I am now curious how I could introduce a slight delay in any gear change to give the Torq a little Time to go low. Or would that be counterproductive?
