I have a project that uses digital switches to output MIDI, I used a very long piece of code to do the note output part, it was basically this for all of the notes:
if(digitalRead(20)==LOW){
if(note50prev == 0){
MIDI.sendNoteOn(50, velocity, MIDIchan);
note50prev = 1;
MIDI.sendNoteOff(50, 0, MIDIchan);
note50prev = 0;
But I want to do this using a for loop, so this is my new code, now I get all of the control changes, but no notes through MIDI:
#include <MIDI.h>
#define MIDIchan 1
#define PBzero 200
int velocity;
int noteCount = 5;
int notes[] = {50, 55, 60, 65, 70};
int pins[] = {40, 41, 42, 43, 44};
int nPrev[] = {0, 0, 0, 0, 0};
MIDI.begin(4);
pinMode(40, INPUT);
pinMode(41, INPUT);
pinMode(42, INPUT);
pinMode(43, INPUT);
pinMode(44, INPUT);
digitalWrite(40, HIGH);
digitalWrite(41, HIGH);
digitalWrite(42, HIGH);
digitalWrite(43, HIGH);
digitalWrite(44, HIGH);
getVelocity();
getPitchBend();
getModulation();
getNotes();
void getVelocity() {
int vel = analogRead(0);
velocity = vel / 8;
void getPitchBend() {
int pb = analogRead(1);
int pitchbend = (pb - 512) * 16;
if(-PBzero < pitchbend && pitchbend < PBzero) {
pitchbend = 0;
MIDI.sendPitchBend(pitchbend, MIDIchan);
void getModulation() {
int mod = analogRead(2);
int modulation = mod / 8;
MIDI.sendControlChange(1, modulation, MIDIchan);
void getNotes() {
for(int thisNote = 0; thisNote < noteCount; thisNote++)
int prevVal = nPrev[thisNote];
int noteVal = notes[thisNote];
int notePin = pins[thisNote];
if(digitalRead(notePin)==LOW){
if(prevVal == 0){
MIDI.sendNoteOn(noteVal, velocity, MIDIchan);
nPrev[thisNote] = 1;
MIDI.sendNoteOff(noteVal, 0, MIDIchan);
nPrev[thisNote] = 0;
Have tried the code in a simple sketch using Serial to check if the buttons are working properly and the code still works in the for loop, that worked, also changed the note to the same note to see if it was a problem with the MIDI library, it wasn't.
Any help would be greatly appreciated.
