output of arduino uno on dso
i want to display output of arduino uno on dso. but i have generated sinewave within arduino uno using for loop. i have already tried sending the output of for loop on some other pin and using it as output pin. i can view the sine wave on serial plotter but not on dso. i am attaching my code alongwith it. can anyone plz help me in this matter.
arduino_sine.ino (403 Bytes)
Please post what you tried
thnk u so much for rplying
arduino_sine.ino (494 Bytes)
The OP’s code
#include "math.h"
  for(double i= -1.0; i<=1.0; i=i+1.0)
      Serial.println(sin(i));
      delay(10);
        for(double i=1.0; i>=-1.0;i=i-0.1);
            delay(10);
A DSO measures a varying voltage and displays it on its screen.
An Arduino cannot produce a varying voltage directly. It’s I/O pins are either at 0v or at 5v.
You could program an Arduino to vary the duty cycle of a PWM output (analogWrite() ) in a sinusoidal pattern and feed that into an averaging circuit to get an average voltage for input to the DSO - but I’m afraid the design of the averaging circuit is beyond my pay grade.
…R
trivalli: thnk u so much for rplying
The code you attached has no output to a pin but as Robin has explained it would not matter even if it did.
