output of pump is not controlled....
part : arduino uno/ npm-4 12v pump , bread board, transister
purpose: pump output control using analogwrite
Source:
int pump = A0; //pump pin AO
void setup ()
pinMode (A0,OUTPUT); //
void loop ()
analogWrite(A0,64); //slow
delay(5000);
analogWrite(A0,255); //fast
delay(5000);
digitalWrite(A0,LOW); // off
delay(10000);
Problem: movement of pump is okay but the pump is not worked following the code…
i want to control pump using analog code for time and output control…
I attach the photo that i connected the parts.
outputcontorl.ino (242 Bytes)
Pin A0 is not capable of PWM output, it is an analog input or non-PWM digital I/O.
You must use pin 3,5,6,9,10 or 11 on the Uno for PWM analog output.
I cannot see your breadboard very well but I do not see a base resistor or a free wheeling diode across the motor. You can damage your Arduino without the proper components in the circuit.
Proper motor control circuits can be found here: https://www.gammon.com.au/motors
WattsThat: Pin A0 is not capable of PWM output, it is an analog input or non-PWM digital I/O.
Thanking for your reply.
As you told me , I change the pin number .
yet,the pump is not workded following the code...
becasuer i am Beginner, i do not understand exactly the circuit.
If I put a diode and a resistor, does this circuit work properly?
OneStep9499: If I put a diode and a resistor, does this circuit work properly?
I'd say the first thing you should do is provide a diagram of the circuit, and not have people trying to decipher that photo.
Here is how to wire a motor and logic level MOSFET transistor. DIG_OUT can be a PWM output.
Without a freewheel diode an inductive load such as motor, relay, solenoid can instantly destroy the circuit
driving it.
First step is to check everything still works by driving a resistor+LED.
That motor can easily pull enough current to melt your breadboard. Breadboards are
not designed for high current.
