How do I view Arduino output on the PC monitor as Notepad?
Thanks
Thanks
what for?
In the bottom section, CTRL-A to select it all, CTRL-C to copy it, then CTRL-V to paste in into Notepad.
I want to view the Arduino output NOT in Serial Monitor but in a text editor like Notepad.
From Arduino to PC monitor.
Thanks
Keyboard Message for Leonardo
When the button is pressed , a text string is sent to the computer as keyboard input. Once you have the Leonardo programmed and wired up, open up your favourite text editor to see the results.
NB: When you use the Keyboard.print() command, the Arduino takes over your computer's keyboard!
This is what I want to do.
You got it from here I guess. https://www.arduino.cc/en/Tutorial/KeyboardMessage
Since the Leonardo is emulating a PC keyboard, if you have a writeable (Text Editor) window open, and the focus (cursor) on that window, the text should appear just as if you had typed it on the keyboard yourself.
6v6gt
Thanks and OK
