Output Oscillator to GPIO on grand central
I’m trying to output the external 32K oscillator to a GPIO on the board, I manged to find few similar examples, but none seemed to work.
This is the last code that I tried and was expecting to see the clock on the PA17 GPIO.
I’m using Platform-IO for coding and compiling.
Any input would be great
#include <Arduino.h>
#if defined(ARDUINO_SAMD_ZERO) && defined(SERIAL_PORT_USBVIRTUAL)
// Required for Serial on Zero based boards
#define Serial SERIAL_PORT_USBVIRTUAL
#endif
  while (!Serial);
  pinMode(36,OUTPUT);
  pinMode(5,OUTPUT);
  OSC32KCTRL->XOSC32K.bit.CGM = 1; // control gain mode: 1 = standard/XT 2 = high-speed/HS
  OSC32KCTRL->XOSC32K.bit.STARTUP = 0; // oscillator startup time, 0 = 62 ms
  OSC32KCTRL->XOSC32K.bit.ONDEMAND = 1; // always run
  OSC32KCTRL->XOSC32K.bit.XTALEN = 1; // enable crystal driver circuit for XIN32/XOUT32 pins
  OSC32KCTRL->XOSC32K.bit.EN32K = 1; // enable the 32 kHz output clock
  OSC32KCTRL->XOSC32K.bit.ENABLE = 1;
  while (!OSC32KCTRL->STATUS.bit.XOSC32KRDY); // wait until crystal oscillator is stable and ready to be used as a clock source
  GCLK->PCHCTRL[TC3_GCLK_ID].reg = GCLK_PCHCTRL_GEN_GCLK1_Val |
                                   (1 << GCLK_PCHCTRL_CHEN_Pos);
  GCLK->GENCTRL[3].bit.SRC = 0x5;
  GCLK->GENCTRL[3].bit.DIV = 1;
  GCLK->GENCTRL[3].bit.GENEN = 1;
  GCLK->GENCTRL[3].bit.IDC = 1 ;
  GCLK->GENCTRL[3].bit.OOV = 1;
  while ( GCLK->SYNCBUSY.reg & GCLK_SYNCBUSY_GENCTRL3 ){
    /* Wait for synchronization */
  PORT->Group[0].PINCFG[17].bit.PMUXEN = 1;
  PORT->Group[0].PMUX[8].bit.PMUXE = 0xc;
  Serial.println("setup done");
void loop(){ }
