output timer retarder
Hi everyone, I’ve been looking all over the net to get any information about my project but didn’t find much info about millis without making a led flashing..
I want to have a 8 sec timed output that run only one time when I flip a switch. If I turn on the switch, I want a output to be HIGH for 8 sec then goes off even if the switch is still on. If the switch is turned off at any time, I want the output to be LOW at anytime.
I have two other blinking leds using millis and I don’t want to use DELAY to make my leds stop blinking! Can someone help me please?
Let's say that, when you read the switch in its normal position, it reads HIGH. What you want to detect is when it goes LOW, not that it is LOW. The state change detection example can show you how you can achieve something like that.
You also need to use a variable to remember that this action has been done.
You need to clarify this specification. Is that even when the 8s is in progress or should the 8s be completed anyway?
Here's some code that compiles for a 2560 that should point you in the right direction.
I've tried to comment effusively. I made an assumption that when you said you need the timed output to "run only one time when I flip a switch" that you meant it. It's easy to change the code to work otherwise if you need (see instances of EVENT_FLAG.)
Note: I didn't try to run it so it very well may have bugs and errors that prevent proper operation. YMMV.
#define OUTPUT_PIN  8 //whatever pin your output is
#define SW_INPUT    9 //whatever pin your switch is tied to
#define LED_PIN     10  //your LED pin
#define LED_TIME    250 //LED toggle rate of 250mS
//bit flags
#define LED_FLAG    0x01  //bit 0 of flags
#define SW_FLAG     0x02  //bit 1
#define OUT_FLAG    0x04  //bit 2
//#define           0x08
//#define           0x10
//#define           0x20
//#define           0x40
#define EVENT_FLAG  0x80  //bit 7 only allow one 8-sec event
#define OUTPUT_TIME_DELAY ((unsigned long)8000) //8000mS == 8-sec
#define SW_READ_INTERVAL  20  //20mS intervals between sw reads
unsigned long
  SwitchReadTimer,
  OutputTimer,
  LEDTimer;
uint8_t
  state,
  flags;
int
  last_switch;
//prototypes
void ProcessOutput( void );
void CheckLED( void );
void ProcessSwitch( void );
  pinMode( LED_PIN, OUTPUT );
  pinMode( OUTPUT_PIN, OUTPUT );
  pinMode( SW_INPUT, INPUT );
  digitalWrite( LED_PIN, LOW );
  digitalWrite( OUTPUT_PIN, LOW );
  flags = 0x00;
  LEDTimer = millis();
  SwitchReadTimer = millis();
  //read switch to establish initial reading
  last_switch = digitalRead( SW_INPUT );
}//setup
  CheckLED();
  ProcessSwitch();
  ProcessOutput();
}//loop
  unsigned long
    timenow;
  timenow = millis();
  if( (timenow - LEDTimer) > LED_TIME )
    flags ^= LED_FLAG;  //toggle LED state
    LEDTimer = timenow; //get time now for next toggle
    //set LED output
    digitalWrite( LED_PIN, (flags & LED_FLAG) ? HIGH:LOW );
  }//if
}//CheckLED
  int
    switch_now;
  //read switch every 20mS (SW_READ_INTERVAL)
  if( (millis() - SwitchReadTimer) < SW_READ_INTERVAL )
    return;
  //reset switch read timer
  //read the switch input
  switch_now = digitalRead( SW_INPUT );
  //look for a change in switch state from the last read
  if( switch_now != last_switch )
    //what happened?
    if( switch_now == HIGH )
      //switch transitioned from low to high (assume this is the switch opening)
      flags &= ~OUT_FLAG; //force off timed output flag
      flags &= ~SW_FLAG;  //indicate switch is open
      //switch transitioned high to low (assume this is the switch closing)
      flags |= SW_FLAG; //indicate switch is closed
      //only process this change once "... that run only one time  when I flip a switch..."
      if( !(flags & EVENT_FLAG) )
        OutputTimer = millis(); //get time now so we can turn it off in OUTPUT_TIME_DELAY mS
        //set output flag to turn timed output on
        //set event flag so we only do this once
        flags |= ( OUT_FLAG | EVENT_FLAG );
      }//if
    }//else
    //log the state of the switch this pass through
    last_switch = switch_now;
  }//if switch has changed state
}//ProcessSwitch
  //if timed output is active, check the time
  if( flags & OUT_FLAG )
      if( (millis() - OutputTimer) >= OUTPUT_TIME_DELAY )
        flags &= ~OUT_FLAG;
  }//if
  //switch has to be CLOSED and time delay timer has to be live
  //for output to be on
  //this assumes "on" == HIGH
  digitalWrite( OUTPUT_PIN, ( (flags & SW_FLAG) && (flags & OUT_FLAG) ) ? HIGH:LOW );
}//ProcessOutput
You don't need a microcontroller to do that.
A simple 555 would do the same.
Thank you . Yes i want to make the output to go low even if the timer is on if the input is switched off
Nrn676:
Will you want to be able to make the output go HIGH again? If so, in what circumstances?
...R
