i need +10 volt from my arduino how i can get it by mega 2560 and DUE?
MGA output is 5 v and DUE is 3.3
can i increase them to 10 volt?!!
how are you powering your mega/due?
Batteries ? USB port? Do you already have a higher voltage available?
You could use a seperate supply for your +10, or ( if you don’t need too much current ) you can buy little ‘boost’ convertors from eg ebay…
Allan
You get +10volt from a regulated 10volt supply.
But I think that's not what you're after, looking at your other thread about a ?10volt? servo.
If you want answers, better stick to that thread.
Post the relevant sections of the datasheet.
Leo..
rainyboy:
The arduino can't supply 10 Volt. So you can't get 10 Volt from the arduino.
What you'll need to do is to explain what you want to do in general --- such as : generate a pulse width modulation signal with voltage levels of 10 Volt and 0 Volt? That's just an example.
If you are talking about analog input for that motor drive it looks like + AND - 10V, if you are going to use pulse or PWM? input , it looks like 24V. Look at page 3 - 26 in the manual.
http://www.deltaww.com/filecenter/Products/download/06/060201/Manual/DELTA_IA-ASD_B2_UM_EN_20141217.pdf
And be aware of the current needed too - a 10V signal might be very low current, but a totally
different circuit would be needed for generating power at 10V where the current isn't tiny.
MarkT:
edgemoron:
edgemoron:
Southpark:
The arduino can't supply 10 Volt. So you can't get 10 Volt from the arduino.What you'll need to do is to explain what you want to do in general --- such as : generate a pulse width modulation signal with voltage levels of 10 Volt and 0 Volt? That's just an example.
Wawa:
You get +10volt from a regulated 10volt supply.But I think that's not what you're after, looking at your other thread about a ?10volt? servo.
Servo motor - Motors, Mechanics, Power and CNC - Arduino ForumIf you want answers, better stick to that thread.
Leo..
allanhurst:
how are you powering your mega/due?Batteries ? USB port? Do you already have a higher voltage available?
You could use a seperate supply for your +10, or ( if you don't need too much current ) you can buy little 'boost' convertors from eg ebay..
Allan
I need a 0-10 v pulse
I have a motor that it need -10 - +10 v pulse and of course -10 +10 PMW output.
is it possible??
is it possible??
Motors need lots of current. Do you mean motor, or motor-controller?
Can you post a link or picture of what you need to control with the arduino?
Is it a motor controller?
The Make and Part number would help us help you with relevant information.
Can you tell us your electronics, programming, Arduino, hardware experience?
Thanks.. Tom...
