Outputting a voltage
I just wanted to know if it's faisable with a arduino, and especially with a arduino BT board to outputting a voltage between 0v and 5v.
For example the number 100 corresponds to 0V and 345 corresponds to 5V.
Thank you
Yes, but not directly. You'll either need to use a PWM output and run that through a low-pass filter to get your voltage, or use something like a SPI/I2C interfaced DAC to do the job. Depending how much precision you want, I might be tempted to start with the first option as you only need a resistor and a capacitor :)
With PWM, 0 would correspond to 0, 128 to ~2.5V, and 255 to 5V.
Ok so i don't need to buy extra hardware ? Actually the values is between 70 and 200 so it should be ok
ZazOufUmI: Hi,
Thank you
You could map it, and then use PWM. Something like this: int x = NumberToOutput; //replace with your value int y = map(x, 100, 345, 0, 255);// map 100 - 345 to 0 - 255 analogWrite(PWMpin, y); // write value to your (PWM-capable) output pin
Thank you for your help. I'm not already at this point of my project, I will try ASAP and I come back if I have more questions.
Hi, See http://arduinoinfo.info http://arduino-info.wikispaces.com/Analog-Output
