Evening, I have a strange one here.
So I have 2 TOF sensors (VL53L1X) and a music box with a motor that you can pick up off amazon etc. So the overview is that TOF sensors read distance and when the distance goes below a certain value (defined into 4 values using a potentiometer) then it will see the music box off.
However as you can see from my serial output below once the motor is set off it "kills" the TOF so they no longer return any values. But then I power cycle the arduino and the it works again until triggered.
21:20:54.074 -> Potentiometer value is 4
21:20:54.120 -> Sensor One 2278
21:20:54.120 -> Sensor Two 1492
21:20:54.166 -> Potentiometer value is 4
21:20:54.213 -> Sensor One 2254
21:20:54.213 -> Sensor Two 1488
21:20:54.259 -> Potentiometer value is 4
21:20:54.305 -> Sensor One 196
21:20:54.305 -> Sensor Two 1488
21:20:54.351 -> Potentiometer value is 4
21:20:54.806 -> Sensor One 109
21:20:54.806 -> Sensor Two 0
21:20:54.806 -> Potentiometer value is 4
21:20:55.807 -> Sensor One 0
21:20:55.807 -> Sensor Two 0
21:20:55.807 -> Potentiometer value is 4
21:20:56.809 -> Sensor One 0
21:20:56.809 -> Sensor Two 0
21:20:56.809 -> Potentiometer value is 4
21:20:57.811 -> Sensor One 0
21:20:57.811 -> Sensor Two 0
21:20:57.811 -> Potentiometer value is 4
21:20:58.813 -> Sensor One 0
21:20:58.813 -> Sensor Two 0
Any ideas what it could be? I'm using a nano for this project.
Thanks in advance
