OV2640 Changing or increasing resolution?
How do I change the resolution?
//This is a modification of ArduCAM_Mini_Video2SD Example
#include <stdint.h>
#include <Wire.h>
#include <ArduCAM.h>
#include <SPI.h>
#include <SD.h>
#include "memorysaver.h"
//ETCG Notes -- PIR Sensor
#define pirPin 2
int pirReading;
// DEFINES
//This demo can only work on OV2640_MINI_2MP or OV5642_MINI_5MP or OV5642_MINI_5MP_BIT_ROTATION_FIXED platform.
#if !(defined OV5642_MINI_5MP || defined OV5642_MINI_5MP_BIT_ROTATION_FIXED|| defined OV2640_MINI_2MP_PLUS || defined OV2640_MINI_2MP|| defined OV3640_MINI_3MP)
#error Please select the hardware platform and camera module in the ../libraries/ArduCAM/memorysaver.h file
#endif
//#define FISHINO_UNO // Nice UNO board with integrated RTC, microSD, WiFi
#define SERIAL_SPEED 115200
#define BUFFSIZE 512  // 512 is a good buffer size for SD writing. 4096 would be better, on boards with enough RAM (not Arduino Uno of course)
#define FRAME_SIZE OV2640_320x240
#define WIDTH_1 0x40 // Video width in pixel, hex. Here we set 320 (Big Endian: 320 = 0x01 0x40 -> 0x40 0x01). For 640: 0x80
#define WIDTH_2 0x01 // For 640: 0x02
#define HEIGHT_1 0xF0 // 240 pixels height (0x00 0xF0 -> 0xF0 0x00). For 480: 0xE0
#define HEIGHT_2 0x00 // For 480: 0x01
#define FPS 0x0F // 15 FPS. Placeholder: will be overwritten at runtime based upon real FPS attained
#define TOTAL_FRAMES 200  // Number of frames to be recorded. If < 256, easier to recognize in header (for manual hex debug)
//set pin 7 as the slave select for SPI:
#define SPI_CS  7
//ETCG Notes -- SD Pin
#define SD_CS 10  // 9 on Arducam adapter Uno and SD shields
#ifdef FISHINO_UNO
#define SD_AUX 10 // Needs to be Output on Fishino Uno for the integrated SD card to work
#endif
#define AVIOFFSET 240 // AVI main header length
//#define DISABLE_SD
// GLOBALS
unsigned long movi_size = 0;
unsigned long jpeg_size = 0;
const char zero_buf[4] = {0x00, 0x00, 0x00, 0x00};
const int avi_header[AVIOFFSET] PROGMEM = {
  0x52, 0x49, 0x46, 0x46, 0xD8, 0x01, 0x0E, 0x00, 0x41, 0x56, 0x49, 0x20, 0x4C, 0x49, 0x53, 0x54,
  0xD0, 0x00, 0x00, 0x00, 0x68, 0x64, 0x72, 0x6C, 0x61, 0x76, 0x69, 0x68, 0x38, 0x00, 0x00, 0x00,
  0xA0, 0x86, 0x01, 0x00, 0x80, 0x66, 0x01, 0x00, 0x00, 0x00, 0x00, 0x00, 0x10, 0x00, 0x00, 0x00,
  0x64, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
  WIDTH_1, WIDTH_2, 0x00, 0x00, HEIGHT_1, HEIGHT_2, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x4C, 0x49, 0x53, 0x54, 0x84, 0x00, 0x00, 0x00,
  0x73, 0x74, 0x72, 0x6C, 0x73, 0x74, 0x72, 0x68, 0x30, 0x00, 0x00, 0x00, 0x76, 0x69, 0x64, 0x73,
  0x4D, 0x4A, 0x50, 0x47, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
  0x01, 0x00, 0x00, 0x00, FPS, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0A, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x73, 0x74, 0x72, 0x66,
  0x28, 0x00, 0x00, 0x00, 0x28, 0x00, 0x00, 0x00, WIDTH_1, WIDTH_2, 0x00, 0x00, HEIGHT_1, HEIGHT_2, 0x00, 0x00,
  0x01, 0x00, 0x18, 0x00, 0x4D, 0x4A, 0x50, 0x47, 0x00, 0x84, 0x03, 0x00, 0x00, 0x00, 0x00, 0x00,
  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x4C, 0x49, 0x53, 0x54,
  0x10, 0x00, 0x00, 0x00, 0x6F, 0x64, 0x6D, 0x6C, 0x64, 0x6D, 0x6C, 0x68, 0x04, 0x00, 0x00, 0x00,
  0x64, 0x00, 0x00, 0x00, 0x4C, 0x49, 0x53, 0x54, 0x00, 0x01, 0x0E, 0x00, 0x6D, 0x6F, 0x76, 0x69,
#if defined (OV2640_MINI_2MP)||defined (OV2640_MINI_2MP_PLUS)
ArduCAM myCAM( OV2640, SPI_CS );
#elif defined (OV3640_MINI_3MP)
ArduCAM myCAM( OV3640, SPI_CS );
#else
ArduCAM myCAM( OV5642, SPI_CS );
#endif
// END GLOBALS
I am thinking this is the parameter to change in the sketch?
OK, I figured it out. In the sketch there is an area defining the resolution and frames per second.
OK, so change the hexadecimals to the the resolution I desire. Its actually commented. What is the hexadecimal for 800x600? Arithmetic...
