OV7670 Help!
Well, I bought this camera, it is for a project for a mobile car robot. The problem is when i was mounting it, somehow one capacitor (C15) fell, it is VERY TINY. I was wondering, if it could still work without it? Or a method to resolder since it is SMD and which hardware would I need?
Thanks in advance
Assuming this is the ONLY surface mount device you're ever likely to assault. Buying the proper kit is probably pointless.
It can be soldered in the normal fasion with a soldering iron, and regular solder. Get your hands on a decent magnifier, it's doable.
Thanks for the reply,any tips tutorial for doing this? Because it's very tiny. Also, should I connect whithout repairing it, what should I expect?
adlerr93:
If you never done ANY soldering before, find someone that has.
adlerr93:
The unexpected.
