Hi,guys. When I try to use ov7670 to be a carma.
I meet some problems.
first,i use eclipse to "run" my code.
In console,it show:
Port name: COM1
Port name: COM9
Looking for image
and there are stop.
no any line and can't get the photo.
second,when i press 1 more times "run"
In console,it show:
Port name: COM1
Port name: COM9
javax.comm.PortInUseException: Port currently owned by SimpleReadApp
at javax.comm.CommPortIdentifier.open(CommPortIdentifier.java:337)
at com.epam.SimpleRead.(SimpleRead.java:40)
at com.epam.SimpleRead.main(SimpleRead.java:29)
So how can i solve this problems and what is that?
also,i want to ask what is comm.API.
What is it? You should always post code as text in your post USING CODE TAGS (</> button on the toolbar). If the code is longer than the forum will allow then attach the file. Generally text is preferrable to images but in some cases posting images is appropriate. You should embed the image using the photo button on the toolbar. You can attach and embed images following the instructions here: http://forum.arduino.cc/index.php?topic=364156.0
My guess is the problem is caused by the port being open in another application. Are you sure you have the correct port selected? You can test this by unplugging and then plugging back in the Arduino and watch which port disappears and reappears.
