Hi!
I've tried this code from bitluni: GitHub - bitluni/ESP32CameraI2S
My camera is OV7670.
The fact is that my board is a TTGO LoRa32 (without OLED, this won´t be something remarkable, I think), which I'll attach in the post. And the issue I have is that when I upload the code, the Serial Output remains in:
Waiting for VSYNC...
This text was set as DEBUG_PRINT(), or something like that. What I had done was changing that for Serial.println(), only to see failures in the code. (If you upload as it is, it won't appear). The point is that it doesn't move forward "Waiting for VSYNC".
Here´s my board. Its micro is ESP32-D0WDQ6. Thanks for all!
Here's the code from the main code (the headers are in github):
#include "OV7670.h"
#include <Adafruit_GFX.h> // Core graphics library
#include <Adafruit_ST7735.h> // Hardware-specific library
#include <WiFi.h>
#include <WiFiMulti.h>
#include <WiFiClient.h>
#include "BMP.h"
const int SIOD = 21; //SDA
const int SIOC = 22; //SCL
const int VSYNC = 34;
const int HREF = 35;
const int XCLK = 32;
const int PCLK = 33;
const int D0 = 27;
const int D1 = 17;
const int D2 = 16;
const int D3 = 15;
const int D4 = 14;
const int D5 = 13;
const int D6 = 12;
const int D7 = 4;
const int TFT_DC = 5;
const int TFT_CS = 2;
#define ssid1 "oppo"
#define password1 "sofiaaaa"
Adafruit_ST7735 tft = Adafruit_ST7735(TFT_CS, TFT_DC, 0/*no reset*/);
OV7670 *camera;
WiFiMulti wifiMulti;
WiFiServer server(80);
unsigned char bmpHeader[BMP::headerSize];
void serve()
WiFiClient client = server.available();
if (client)
//Serial.println("New Client.");
String currentLine = "";
while (client.connected())
if (client.available())
char c = client.read();
//Serial.write(c);
if (c == '\n')
if (currentLine.length() == 0)
client.println("Content-type:text/html");
client.println();
client.print(
"<style>body{margin: 0}\nimg{height: 100%; width: auto}</style>"
"<img id='a' src='/camera' onload='this.style.display=\"initial\"; var b = document.getElementById(\"b\"); b.style.display=\"none\"; b.src=\"camera?\"+Date.now(); '>"
"<img id='b' style='display: none' src='/camera' onload='this.style.display=\"initial\"; var a = document.getElementById(\"a\"); a.style.display=\"none\"; a.src=\"camera?\"+Date.now(); '>");
client.println();
currentLine = "";
else if (c != '\r')
currentLine += c;
if(currentLine.endsWith("GET /camera"))
client.println("Content-type:image/bmp");
client.println();
client.write(bmpHeader, BMP::headerSize);
client.write(camera->frame, camera->xres * camera->yres * 2);
// close the connection:
client.stop();
//Serial.println("Client Disconnected.");
wifiMulti.addAP(ssid1, password1);
//wifiMulti.addAP(ssid2, password2);
Serial.println("Connecting Wifi...");
if(wifiMulti.run() == WL_CONNECTED) {
Serial.println("");
Serial.println("WiFi connected");
Serial.println("IP address: ");
camera = new OV7670(OV7670::Mode::QQVGA_RGB565, SIOD, SIOC, VSYNC, HREF, XCLK, PCLK, D0, D1, D2, D3, D4, D5, D6, D7);
BMP::construct16BitHeader(bmpHeader, camera->xres, camera->yres);
tft.initR(INITR_BLACKTAB);
tft.fillScreen(0);
server.begin();
void displayY8(unsigned char * frame, int xres, int yres)
tft.setAddrWindow(0, 0, yres - 1, xres - 1);
int i = 0;
for(int x = 0; x < xres; x++)
for(int y = 0; y < yres; y++)
i = y * xres + x;
unsigned char c = frame[i];
unsigned short r = c >> 3;
unsigned short g = c >> 2;
unsigned short b = c >> 3;
tft.pushColor(r << 11 | g << 5 | b);
void displayRGB565(unsigned char * frame, int xres, int yres)
int i = 0;
i = (y * xres + x) << 1;
tft.pushColor((frame[i] | (frame[i+1] << 8)));
camera->oneFrame();
serve();
displayRGB565(camera->frame, camera->xres, camera->yres);
