OV7670 without FIFO getting garbage image
I am a newbie and trying to capture some frames out of the OV7670. I am using arduino UNO and I followed this.
but when i capture the image i get some random garbage image like the attached image.
(deleted)
Attached the image …couldn’t attach as i wasn’t allowed to post before 5 min.
Code:
main.c
#define F_CPU 16000000UL
#include <stdint.h>
#include <avr/io.h>
#include <avr/interrupt.h>
#include <util/twi.h>
#include <util/delay.h>
#include <avr/pgmspace.h>
#include "ov7670.h"
/* Configuration: this lets you easily change between different resolutions
 * You must only uncomment one
 * no more no less*/
#define useVga
//#define useQvga
//#define useQqvga
static inline void serialWrB(uint8_t dat){
 while(!( UCSR0A & (1<<UDRE0)));//wait for byte to transmit
 UDR0=dat;
static void StringPgm(const char * str){
 do{
 serialWrB(pgm_read_byte_near(str));
 }while(pgm_read_byte_near(++str));
static void captureImg(uint16_t wg,uint16_t hg){
 uint16_t lg2;
#ifdef useQvga
 uint8_t buf[640];
#elif defined(useQqvga)
 uint8_t buf[320];
#endif
 StringPgm(PSTR("RDY"));
 //Wait for vsync it is on pin 3 (counting from 0) portD
 while(!(PIND&8));//wait for high
 while((PIND&8));//wait for low
#ifdef useVga
 while(hg--){
 lg2=wg;
 while(lg2--){
 while((PIND&4));//wait for low
 UDR0=(PINC&15)|(PIND&240);
 while(!(PIND&4));//wait for high
#elif defined(useQvga)
 /*We send half of the line while reading then half later */
 while(hg--){
 uint8_t*b=buf,*b2=buf;
 lg2=wg/2;
 while(lg2--){
 *b++=(PINC&15)|(PIND&240);
 UDR0=*b2++;
 /* Finish sending the remainder during blanking */
 lg2=wg/2;
 while(lg2--){
 UDR0=*b2++;
#else
 /* This code is very similar to qvga sending code except we have even more blanking time to take advantage of */
 while(hg--){
 lg2=wg/5;
 while(lg2--){
 UDR0=*b2++;
 lg2=320-(wg/5);
 while(lg2--){
 UDR0=*b2++;
#endif
int main(void){
 cli();//disable interrupts
 /* Setup the 8mhz PWM clock
 * This will be on pin 11*/
 DDRB|=(1<<3);//pin 11
 ASSR &= ~(_BV(EXCLK) | _BV(AS2));
 TCCR2A=(1<<COM2A0)|(1<<WGM21)|(1<<WGM20);
 TCCR2B=(1<<WGM22)|(1<<CS20);
 OCR2A=0;//(F_CPU)/(2*(X+1))
 DDRC&=~15;//low d0-d3 camera
 DDRD&=~252;//d7-d4 and interrupt pins
 _delay_ms(3000);
 //set up twi for 100khz
 TWSR&=~3;//disable prescaler for TWI
 TWBR=72;//set to 100khz
 //enable serial
 UBRR0H=0;
 UBRR0L=1;//0 = 2M baud rate. 1 = 1M baud. 3 = 0.5M. 7 = 250k 207 is 9600 baud rate.
 UCSR0A|=2;//double speed aysnc
 UCSR0B = (1<<RXEN0)|(1<<TXEN0);//Enable receiver and transmitter
 UCSR0C=6;//async 1 stop bit 8bit char no parity bits
 camInit();
#ifdef useVga
 setRes(VGA);
 setColorSpace(BAYER_RGB);
 wrReg(0x11,25);
 setRes(QVGA);
 setColorSpace(YUV422);
 wrReg(0x11,12);
#else
 setRes(QQVGA);
 wrReg(0x11,3);
#endif
 /* If you are not sure what value to use here for the divider (register 0x11)
 * Values I have found to work raw vga 25 qqvga yuv422 12 qvga yuv422 21
 * run the commented out test below and pick the smallest value that gets a correct image */
 while (1){
 /* captureImg operates in bytes not pixels in some cases pixels are two bytes per pixel
 * So for the width (if you were reading 640x480) you would put 1280 if you are reading yuv422 or rgb565 */
 /*uint8_t x=63;//Uncomment this block to test divider settings note the other line you need to uncomment
  do{
  wrReg(0x11,x);
  _delay_ms(1000);*/
#ifdef useVga
 captureImg(640,480);
 captureImg(320*2,240);
#else
 captureImg(160*2,120);
#endif
 //}while(--x);//Uncomment this line to test divider settings
