Oven Temperature Sensor
Hi everyone,
I'm looking into interfacing an existing oven temperature sensor to an Arduino.
The oven sensor is a resistance based sensor varying resistance between 1143 ohms @ 100 F to 1949 ohms @ 500 F.
(More information Oven Temperature Sensors Demystified)
Someone suggested hooking it up like a photocell with an analog pin but I am concerned that I would not get the full range of detail as the photocell goes into the K ohms range and the oven sensor does not. I'd like to be able to adjust it and then perhaps build in a table or formula to get a flat response.
Does anyone have any idea for the best way to do this? Constant current source, perhaps? I'm new to all of this.
Thanks
  • Mike
make a voltage divider
5V -----[2K2] -----A-----[temp sensor] ---- GND.
The A is connected to the Arduino analog port
The voltage at A will be between
1143/(2200+1143) * 5 Volt =~ 1.7V
1949/(2200+1949) * 5 Volt =~ 2.34V
If you use an external reference of 2.5V for the ADC giving these readings
1.7V ==> ~695
2.34V ==> ~957
// these numbers should be callibrated manually as the 2K2 resistor has some tolerances.
Then you can do
int temp = map(analogRead(A0), 695, 957, 100, 500); // linear interpolation
get the idea?
(the assumption is that the temp is linear with resistance)
// above might contain some math error
