I am working on a project that runs off 5V dc... it will be destroyed if 12v dc is applied... what is the best way to achieve this? I read somewhere that adding a voltage regulator to the project could do the trick... but the problem is that they require at least 7v to give me 5vdc... I want to be able to plug in 5vdc, but not have the project be distroyed if someone accidently plugs in 12v...
What you would like to happen if > 5V is applied? Using a sepic converter the circuit will work in any case, if like to stop it and have fault detection an LTC4365 and an external mosfet can do the job.
A zener diode in parallel with the load along with a with fuse will "crowbar" (short-out) when the zener voltage is exceeded, blowing the fuse. And, since a zener works like a regular diode in the forward direction, the circuit will also "crowbar" if the voltage is connected backwards.
ilguargua:
Ciao, Ale.
I would be happy with either the project continuing to run (it is a touchscreen with an arduino due and an esp8266), or not running.... I just dont want to destroy the screen by accident since it costs $60 to replace...
DVDdoug:
A zener will just fail. A crow-bar circuit is needed - typically a zener triggering an SCR - that will
definitely blow the fuse. Zeners dissipate lots of power when clamping, an SCR will crow-bar the
voltage down to 1V or so (thus not dissipating much power) and definitely force the fuse to blow
or the supply to cutout.
It says that the over current protection will trigger depending on the value of the r1 resistor? What should it be if i want to trigger it if it goes more than 5v?
Also, what should the fuse current be? I was thinking of pulling one of the fuses off an arduino mega as i have several of them lying around....
Also, is there a module that has all of this already in it? I'd sorta like to keep it as compact as possible and if i have to solder everything its going to be BIG....
but there are no values on that.... also, if is search for an "scr" on mouser i'm not sure what i am looking for.... I googled it and know it is some sort of schottky diode..
If you got to the Digikey site and search "SCR" you'll find plenty, too.
Alternatively, a buck/boost DC-DC converter might be worth considering, (as ilgargua meant when he mentioned a "sepic converter").
You can input a wide range of voltages, above and below 5V, and still get 5V output. eBay sell them for a couple of dollars. Just search "buck boost module", then read the listing carefully to ensure it steps both up and down, because often the listing title says "Buck Boost" when they're only one or the other.
Here's an example:- Boost Buck DC adjustable step up down Converter XL6009 Module Voltage S
(I don't know how good that particular one is, it's purely an example, the first I found.)
The zener voltage depends on the voltage, the resistor depends on the current needed to trigger the
SCR, the SCR depends on the kind of current you'll have to handle if it activates.
Another word for SCR is thyristor. It is not any kind of diode, schottky or otherwise.
